Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-23-2004, 09:19 PM
ReddragonDC2 ReddragonDC2 is offline
catalytic converter
i bought this hi-flow cat converter for my 97 Integra LS, but it did not have a slot to put the sensor back in...so right now it is hanging there. what should i do with it?
Old 05-24-2004, 04:37 PM
freekinfreak freekinfreak is offline
get a new cat., or get an o2 simulator.
http://www.highrevmotorsports.com/ca...p?cPath=80_330
Old 05-24-2004, 10:57 PM
would it be possible to have a shop put a hole for the sensor?
Old 05-25-2004, 02:09 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: catalytic converter
um.. couldn't you just drill a hole in the downpipe, weld the right size nut on and be done with it? it's just an o2 bung isn't it?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 05-25-2004, 04:23 AM
wickedplastikman wickedplastikman is offline
i guess it can be done, but if you can return the cat then return the cat. there are plenty of hi-flow cats that already have an o2 bung on them. there wont be a price difference and it will save you a lot of time and headaches
99 teg ls turbo:
Drag gen III turbo, Blitz BOV, Blitz Boost Controller, AEM Standalone ECU, MSD Ignition, MSD Blaster SS Coil, MSD Cap, Skunk2 Intake Manifold, AEM Fuel Rail/Fuel Pressure Regulator, ACT XCT Clutch, ACT Aluminum Flywheel, Nex SS Coilovers, Thermal Stainless 3" Exhaust, Skunk2 Short Shifter/Knob, Rota 15" Black Slipstream Wheels, Falken Azenis Tires, Brembo Rotors, Axxis Metal Masters, Type R Wing/Seats, VIS Carbon Fiber Hood
Old 05-25-2004, 01:48 PM
http://search.ebay.com/o2-bung_W0QQs...1QQsonewuserZ1
Drill it out yourself and take it to a tech. school, they should do it for free.Or a garage, but you might pay up to $30 for 2 min. of work.
Old 05-25-2004, 05:59 PM
i heard that there is 2 o2 sensors on the integra exhaust system, one in the header and one in the catalytic converter...so i have the one in the header plugged in and i also heard it is ok to only have one of the o2 sensors working/plugged in...
Old 05-25-2004, 09:44 PM
5spd 5spd is offline
The downstream o2 sensor tells the pcm if your catalytic converter is working by comparing info gathered by the upstream to the info gathered by the downstream. If you think its ok then its ok but that info is needed by the pcm to determine how much fuel you really need.
Old 05-26-2004, 12:37 AM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
gotta have 2 or u will get check engine
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 05-26-2004, 09:46 PM
Re: Re: catalytic converter
i have two, but one is hanging out...and the check engine light is not on
Old 05-27-2004, 12:32 AM
how long has it been hanging for? takes a few days
Clear Corners
Iridium Spark Plugs
Old 05-27-2004, 04:37 PM
about 5 days
Old 05-27-2004, 05:40 PM
i got the problem fixed now...i went to the local muffler shop and they are going to weld a hole in the cat. converter for me
