Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 05-23-2004, 08:10 PM
Hatrick101's Avatar
Hatrick101 Hatrick101 is offline
New Projectors Broken
I just bought some new projectors for my car 2 weeks ago and are already having problems. On one light the high beam and the low beam are not working but when i go over bumps sometimes they flicker on and off. The other side is fine. I tried fiddling with the wires but nothing happened. Anyone have any suggestions on how to fix them?
Old 05-24-2004, 02:00 AM
Al_Bundy's Avatar
Al_Bundy Al_Bundy is offline
Re: New Projectors Broken
it's not the head lamp, flick on and off mean some wires loose. Make sure light bulb is snug fit into headlight socket and that it's snug into the headlamp.
Old 05-24-2004, 05:18 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
yup...rather your bulbs are losse in the socket, some wire connections are loose(even tho they may appear not to be due to being inside a connector) or you have a short(frey) ina wire that is rubbing and grounding out.....you need to follow the whole wiring process of the lamp install and find the problom.....if you fail to locate the problom..you need to scrap all your wiring and re-wire the entire set-up to ensure the problom is fixed...also remember to check/change your fuses in case they trip..this will make sure you dont think you havent fixed the problom when you have due to them not working because of a tripped fuse.
Old 05-24-2004, 08:37 PM
Hatrick101's Avatar
Thanks for the info, pisses me off cause i just got these but oh well...thanx
