Old 05-23-2004, 07:06 PM
fakehatch fakehatch is offline
Angry window crank re-installation
I've got a 96 civic and I repaired a door handle after a theft attempt, and the only thing I can't do is the stupid window crank. If anyone out there can help I'd appreciate it. I have the pin but can't figure out how to get it through those small slits. Thanks for the time...Ras
Old 05-24-2004, 02:43 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
I get that pin so it is just sitting on the crank, but not all the way on, then I put the crank where it goes, and use a flat screwdriver to give the pin a poke, which pops it into it's locked position.
Old 05-25-2004, 06:14 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: window crank re-installation
Are you refering to the C-clip? Sometimes you can go ahead and completely install the clip on the handle then pop the whole thing onto the splines coming out of the door. Although this only works if the splines are somewhat rounded at the end, otherwise use the flat screwdriver trick mentioned before.
