Old 05-23-2004, 07:01 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
16g install problems
Hey I just installed my small 16g and i have 2 problems.
1- i have a oil leak from the banjo bolt that goes into the turbo and i have tightend the crap out of it and it still leaks, could i put teplon tape on it or would that stuff just melt or hurt the turbo.
2- i know i need new injectors but they say i can use the stock ones if i dont boost over 13psi. Well i m at 8 psi and i get fuel cut bad, but only when i floor it if i keep it a little past halway throttle i can tach all the way to 6k, if i floor it i get fuel cut at like 4 r 5k
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 05-23-2004, 09:38 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 16g install problems
Did you use a crsh washer on BOTH sides of that banjo fitting? Dont over tighten it (~22 ft-lbs), they break easily! The threads are not meant to seal, you need crush washers on both sides. You can get them from the dealer if you lost them, or need new ones (if they are both there and it leaks, you need new ones). Sometimes you can find aluminum ones at the hardware store, though I forget what they call them. They jus have to be soft, like copper (stock) or aluminum....
There is no way you are getting fuel cut at 8 psi, on any turbo. You must be experiencing some type of stutter from an ignition related problem, or there are some boost leaks as a result of the turbo installation causing an over rich condition (can also induce real fuel cut at low boost, but it would have to be a huge leak to get it at 8 psi). Make the leak tester on vfaq and test it if you havent already.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-23-2004, 09:53 PM
Yea i have both crush washers on but i think i'm going to order the SS oil line b/c alot of people have told me they had the same oil leak problem from those banjo bolts.
I know i shouldnt be getting fuel cut at 8psi b/c they say on the stock stup it should be good until 13psi. I have no idea wtf is wrong. Its like im getting tomuch feul b/c at half trottle i can tach all the way to redline but if i try to WOT it, it like pops or something and falls on its face for a second and i hurry and let off it.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 05-23-2004, 10:01 PM
AF - Advisor
Sounds like a boost leak.
Also for what its worth, I never saw fuel cut on the T25 (dont think its big enough) or the 14b. But I check constantly for boost leaks.
Also note that buying a stainless feed line doesnt get rid of the banjo fitting, iut just comes with another one
Kevin Jewer
Old 05-23-2004, 10:04 PM
oh lol, but thanks for the help, so i'll check tomorrow all my intecolling pipes and all hopefully i can fix this. Also one more comment on my turbo. I seen on a few pics on websites of a small 16g that they have a boost source nipple on the 16g's ive seen on the websites but i didnt have one on mine, the guy at exteampsi.com said hook the mbc
up to the wastegate and to a vacuum source ( i T'd mine into the same hose as my boost guage.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 05-24-2004, 01:27 AM
AF - Advisor
Yeah, most poeple run it off the BOV line. That way you can use the larger 1/4" lines instead of the smaller 3/16 lines used elsewhere on the car. Helps a bit with boost spike.
Kevin Jewer
Old 05-24-2004, 01:35 AM
soyee7's Avatar
soyee7 soyee7 is offline
Banned
you may want to invest in some t-bolt clamps to ensure no leaking from the piping. Has anyone come across any good deals on some t-bolt clamps?
Old 05-24-2004, 02:16 AM
AF - Advisor
YES! Most DSM shops charge 5 bucks for tbolt clamps. I just picked up a dozen from NAPA. Even a 4.75 inch tbolt clamp was only 2.69. They had every size I needed in stock too. Amazing... NAPA is the place to be for tblot clamps. They have a couple styles too, depending on how much clamping force you need. Check it out.
Kevin Jewer
Old 05-24-2004, 10:26 AM
I think i found my problem, i looked under my hood and moved the airfilter/MAS and noticed that the dumb tube that runs to the BOV was loose, i tightend it and havnt tried it yet b/c im still in class, but hopefully that will be my fix.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 05-24-2004, 01:41 PM
ok that didnt fix it, y would it only cut out when im at WOT and not when im like half throttle. I can only tach to 4-5k rpm till it cuts out at WOT with about 8 or 9 psi, but when i go half throttle and push it to about 8psi i can tach all the way to redline.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 05-24-2004, 02:01 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Boost leak.
Kris
2012 Genesis Coupe 2.0t
Old 05-24-2004, 03:03 PM
Ok i fixed it, i went back and addjusted all the hose clamps and tightend them up a crap load and adjusted the boost a little and now its working, thanks for all the info, I'm going to the track this weekend and i'll post sometimes
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 05-24-2004, 10:48 PM
soyee7's Avatar
Banned
good stuff man
Old 08-12-2004, 08:42 AM
OK sorry to bring this thread from the dead but i found m problem. The guy that installed my motor tok a look a it and said Im running rich, and that is why i was shooting carbon out the exhaust in the morning with the moister in the pipe. How the hell am i running rich. is there anyway to adjust it under the hood, without going buy that S-AFC. is the S-AFC a good fuel computer for what mods i have. I dont have the budget for the DSMLink and im not planning on modding it anymore till i get out of college. in about 2years.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 08-12-2004, 09:53 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
check for boost leaks! is your BOV recirculating or vented? a S-AFC is a great fuel controller for what mods you have and if you did get it you can lean/richen your exhaust to where it runs perfect!
