Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 05-23-2004, 05:05 PM
Rknittel Rknittel is offline
Car stalls while driving & idles rough
I recently rebuild the engine. Car stalls while driving but always start back up immediately. I have replaced the camshaft sensor and the crank shaft sensor. After review several posting, the MAS air flow sensor maybe the problem. Can anyone tell me how should I disconnect to test. ie: disconnect while car is running or while car is shut off?
Any suggestions would be helpful.
Robert
Old 05-27-2004, 11:27 AM
92 Lumina 92 Lumina is offline
Re: Car stalls while driving & idles rough
Also check the EGR valve
Old 07-18-2004, 06:01 PM
theyevmeyster theyevmeyster is offline
The cam sensor has an interuptor on the cam gear, take off the cam sensor and see if you can see the interuptor, you can twist the balancer until you see it. Using two people it the best advice i can give.
