Old 05-23-2004, 04:53 PM
ndaniel7 ndaniel7 is offline
Removing a starter
Can someone tell me how I can go about removing the starter from a 95 chevy blazer 4.3 v6 4WD I got the mounting screws undone but I can't reach the wires. The starter is loose but I can't get it to come out of there I don't know what else to do. It seems that the starter is too long to take it out from there. Can someone please give me some ideas or info on what I need to do to get it out from under the truck.
Old 05-25-2004, 02:32 PM
Macgyver007's Avatar
Macgyver007 Macgyver007 is offline
Send a message via MSN to Macgyver007
Re: Removing a starter
I had a 94, pretty sure its the same one. But I had to loosen the engine mount and hoist up the engine on a floor jack to get enough clearence. I have heard of others that remove the cross member under the transfer case to to the same thing. One way or the other, its not a fun job... I feel for you
I love these trucks !!
I have had an 84 and 89 Pickup X-cab P/U also assorted 2 Dr Blazers.
I now own a 97 4 Dr.
Still a work in progress but ...
http://www.cardomain.com/memberpage/761008
Macgyver
Ontario, Canada
Old 07-14-2004, 12:10 AM
JoeCanadian JoeCanadian is offline
Thumbs down
I sure hope it isn't that hard to remove the starter......If it is this will be the last chevy I will ever own.
I am having the same problem The starter just won't come down and this is on a 1987 Jimmy, I guess I'll just try the crost member.
Old 07-15-2004, 09:42 AM
Hi Ndaniel
I am not sure the 95 is the "older" body style. The ones with the sealed beam Headlights. if so My post above still applies. One you get the engine moved up out of the way the starter will drop out and you can disconnect the wires.
J
Macgyver
Ontario, Canada
Old 07-15-2004, 09:43 AM
sorry last post was supposed to be for Joe. and yes the 87 is the same way
Macgyver
Ontario, Canada
Old 07-15-2004, 04:36 PM
Yea I found that out, I unbolted the motor mounts lifted the motor and droped the cross beam and I still can't get the %&&ing thing out!!!!
So today I called my mechanic, he can deal with it.
Thanks for all the help
