Old 05-23-2004, 02:05 PM
daveid daveid is offline
rotating tires
this is my first time rotating tires and i know to make sure they are at the right lbs when putting them on, but is there anything else im suppose to do?And do you know about how many lbs a corolla would need?
Thanx
Old 05-23-2004, 10:24 PM
rscamaro305 rscamaro305 is offline
I figured it is my duty to help you because i guess i am a "Tire Pro" Customarily when rotating tires you cross the non drive tires. so sinse your car is front drive take the 2 fronts and send them straight back ang your left front should become the right rear and your right front becomes the left rear. I usually fill car tires up to 32-35 psi dependinfg on the tires max rated pressure. and a common general rule on torquing car wheels is between 80 and 90 ft/lbs. Hope this helps.
Old 05-23-2004, 11:27 PM
Re: rotating tires
thanx man
