Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-23-2004, 05:38 AM
Baby CRuizer Baby CRuizer is offline
Unhappy transmition problems?
it's been a long day of racing... and just before i went home my first gear started fukkin up . It's was so hard for me to get into it??? wuts going on is my tranny messing up or wut?.
oh yeah will intake and header void ur warrenty? because if it does im kinda srewed. : .
Old 05-23-2004, 09:42 AM
crazy_canuck crazy_canuck is offline
Re: transmition problems?
Is it a grinding? If so a lot of people have complained about it (although I don't have it so you'll have to talk to someone who has it). Some dealers fix.
What intake? Short/V2 or Cold? What header? Race or Shorty?
Regardless, they should warranty it because they can only void it if it caused a problem, however, a header or intake can't mess up the tranny. Although, they might be a bit unhappy if you have a CAI or race header, but I doubt that'll cause them to void it.
Good luck, and I think it'll be all good for ya!
Old 05-23-2004, 01:10 PM
well no it's not a grind... that happens on third gear from time to time. I just couldnt get it in gear , it was like stuck.
I got the rd injen intake and the 4-2-1 dc header.
Old 05-23-2004, 01:19 PM
Ok, a cold air and a shorty. The header shouldn't cause any problems with warranty, and unless you hydrolock (get the filter submered in water) the car, there shouldn't be any warranty problems.
As for not getting in gear, i'm not really sure....
Old 05-23-2004, 01:39 PM
It might be the clutch, but don't take my word on that...
Old 05-23-2004, 03:51 PM
RSX-S777's Avatar
RSX-S777 RSX-S777 is offline
Yeah- the grind everyone is complaining about is most prevalent in 2nd-3d. I've had the problem youre describing in my Mustang. Usually just let my foot up off the clutch slightly and it drops right in.
I've got a fever. And the only prescription is more cowbell...
Old 05-23-2004, 04:35 PM
Not everyone
Old 05-24-2004, 04:46 PM
RSX-S777's Avatar
Everything seems to be rosier in CANADA! Bastard
Old 05-24-2004, 07:51 PM
Don't worry, you'll lighten up once you get your Cher CD back
Old 05-25-2004, 05:36 PM
RSX-S777's Avatar
Old 05-25-2004, 09:50 PM
mmont0's Avatar
mmont0 mmont0 is offline
Yeah, I had a neon that had the same problem. If there is no grinding, your shifter bushings might be shot. Just check inside your engine, locate the end of the shifter cable and look at the bushings(usually rubber pieces connecting to the shift lever). Then check the ends of the cables inside your car under your shifter. This will require you to take the center panel off.
If it's not that, I don't know what it is.
Man, I couldn't remember who I lent that CD to! I don't know why RSX-S777 gave it to you to borrow since it's mine!
Old 07-02-2004, 08:12 PM
04superrsxs 04superrsxs is offline
its probably the syncros
Old 07-06-2004, 06:04 PM
THEOLDMAN THEOLDMAN is offline
If they can prove the problems were caused by racing (that being any timed event any where), you voided your warrantee yourself. Auto makers are looking hard at items that can be damaged in racing and if your mileage doesn't support the amount of wear and tear on the parts you can pretty much expect to have to fight to get warrantee coverage.
Driving the Milano Red RSXTypeS or the White '89 325i listening to Blues & Jazz
Old 07-07-2004, 01:46 PM
Yup. Mazda has spies at tracks and they void warranties immediately, and if you own a Mitsu EVO and post race times on the internet, they'll get you for that.
It's amazing. They want you to take it to the track, but when you do they punish you.
