Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 05-22-2004, 08:27 PM
96Civic_Coupe 96Civic_Coupe is offline
Banned
400 Watts
ok, i've made up my mind, i wanna push 400 watts for 400$ or less, and i want two 10" woofers,a box,and an amp all for 400$ or less.
any suggestion???
Old 05-22-2004, 11:34 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
better start hitting the sales tables and places like ebay
Old 05-22-2004, 11:50 PM
mjshort18 mjshort18 is offline
Re: 400 Watts
definately ebay!
Old 05-23-2004, 01:02 AM
Banned
yea i know where to look but, if i wanna push 400watts out of two 10" woofers 200rms ea. what specs should i look for in an amp?
Old 05-23-2004, 09:18 PM
Re: 400 Watts
it depends on the ohms of the woofers. you need to get an amp that can push 200 watts rms at the recomended ohms of your subs.
Old 05-23-2004, 09:46 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: 400 Watts
I answered your question on that other post, but you'll want an amp that can push either 200 watts, or more, RMS x 2 at 2ohms or a D class amp that can push 400 watts or more at 1 ohm.
Empty Pockets Racing Member #1
Old 05-23-2004, 10:48 PM
Banned
another question, i'm getting the Alpine SPS-170A's for my front deck but, crutchfield tells me they wont fit and circuit city tells me they will.they will fit right? this goes for the SPS-690A's too.
Old 05-23-2004, 10:51 PM
GScivic7's Avatar
Re: 400 Watts
the 170s will fit. If anything you might have a depth problem, but 2.25" isn't that deep. As for the 690s, 6th gen civics come with 6x9's in the rear deck right? If so, the only worry would be depth again. You might hit the trunk springs with these speakers.
Old 05-23-2004, 10:54 PM
Banned
2.25"? will it be hitting something or will it be hanging? and for the back is that something to worry about?
Old 05-23-2004, 10:57 PM
GScivic7's Avatar
Re: 400 Watts
if you do have a depth problem with those door speakers, more than likely it'll be from the window hitting the speaker basket inside the door when you roll the window down. You can always make a small spacer to cure the problem though.
As for the trunk springs, that is something to worry about. If they hit the trunk springs, well, that means they won't fit without modifying something. You could remove your trunk springs, but then the trunk won't hold it self open, or you could again make some spacers to raise the speaker, but I think that would look funny on the rear deck.
Old 05-23-2004, 11:08 PM
Banned
Front Door
Depth: 2 1/8
Height: 11/16
Rear Deck
Depth: 8
Height: 1/2
Is there gonna be a problem??
Old 05-23-2004, 11:14 PM
GScivic7's Avatar
Re: 400 Watts
are those dimesions for the doors and rear deck or the speakers? The 170s are 2.25" deep, so you might have a bit of a problem with them, but you shouldn't have to worry about the rear deck.
Old 05-23-2004, 11:17 PM
Banned
thats what's available for "easy fit speakers" according to crutchfield
Old 05-23-2004, 11:21 PM
GScivic7's Avatar
Re: 400 Watts
well, I say buy them anyways. making spacers for your door speakers isn't hard at all. And you have more than enough room in that rear deck for the 6x9's. 1/8th of an inch isn't much, those 170's may fit in there without any sort of hassle.
Old 05-23-2004, 11:24 PM
Banned
thanks alot, you've been a good help
