Old 05-22-2004, 02:18 PM
1989Buickguy 1989Buickguy is offline
A/C Question
I'm trying to give my car a shot of R-12. However, I can't get the compressor to cycle. I tried unplugging the connector on the line by the condensor and jumping the two terminals, however the fan turns on but not the compressor. Is there another connector somewher that I have to jump?
Thanks
Old 05-23-2004, 04:56 PM
bustedratchet bustedratchet is offline
Re: A/C Question
Try disconnecting the battery for a minute.
Old 05-24-2004, 09:58 AM
I don't understand how disconnecting the battery would help. Please explain?
Old 05-26-2004, 09:25 AM
Re: A/C Question
Can somebody help me out with this please?
Old 05-26-2004, 09:31 AM
mjgjr72 mjgjr72 is offline
Re: A/C Question
use a test light and check the connector on the compressor to see if you are getting power, the compressor clutch may be bad.
Old 05-26-2004, 06:45 PM
public's Avatar
public public is offline
Check the electrical connector on the compressor. This is for the clutch. Also check the fuses for the A/C system. Good luck
Old 05-26-2004, 07:32 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: A/C Question
If you are low on R-12 the computer stores a code. Disconnecting the battery will clear the code long enough for the comp to come on and suck the R-12 out of the can.
Do what bustedratchet suggested.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
