Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-22-2004, 01:25 PM
TSRyder6's Avatar
TSRyder6 TSRyder6 is offline
Send a message via AIM to TSRyder6
Talking Can I make my Integra fast without Turbo or Swap?
Turbo and Engine Swap cost lots of money...and right now I ain't got too much. I got a GSR with B18C1 Engine (which I think its fast) but what things can I get to make my car faster? I know about Intake, Headers and Exaust...but other than that what's some good upgrades I can put in my car to make it faster?
Old 05-22-2004, 01:57 PM
95TegSE's Avatar
95TegSE 95TegSE is offline
Re: Can I make my Integra fast without Turbo or Swap?
Didn't you just buy the Greddy turbo kit? Are you tryin to pull something here mister?
From the foothills to the bay, it shall ring, as we sing,
It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail!
Old 05-22-2004, 02:01 PM
schecter schecter is offline
Banned
Send a message via AIM to schecter
pulleys, performance chip, believe it or not spark plugs but not too much gain cam gears and shafts, theres alot of other things besides wut u have listed. just look around u have a car with a shit load of potential, however all those parts are gonna make alot of horsepower but turbo is the best too bad u cant afford one neither can i so i know ur pain
Old 05-22-2004, 02:06 PM
motoringhack motoringhack is offline
Rising rate fuel pressure regulator - good spark plugs (NGK palladian) and leads (magnecor) - match ports - chip is available for Integra (is this a Type 'R'?). That lot should give you about 180 bhp if it's a V-TEC.
Old 05-22-2004, 09:01 PM
TSRyder6's Avatar
O naw man...i was asking lots of questions about it and am thinking about it but its lots of money...anywayz so pulleys, performence chip and bunch of other little things will give me good amount of gain or if i want big power i should stick with turbo?
Old 05-22-2004, 09:24 PM
Crippy's Avatar
Crippy Crippy is offline
intake manifold , higher c/r pistons , ecu upgrade , maybe some throttle bodies , msd , quite a bit , the gsr is a very good n/a setup motor ...
Old 05-22-2004, 09:27 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
www.homemadeturbo.com
that's a fairly cheap way to go
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 05-22-2004, 09:48 PM
TSRyder6's Avatar
Posted by BLU CIVIC - 05-22-2004 at 09:27 PM
Thanks Blu civic i already checked that out!!
Old 05-22-2004, 10:00 PM
BLU CIVIC's Avatar
調整器
personally....i think going NA on ur ar would probably cost too much...that's why i recommend a homemade turbo...itz a cheap build as long as u find cheap parts
The name's Adrian
2011 CR-Z - Stock
Old 05-23-2004, 01:54 AM
xsimpleaznx's Avatar
xsimpleaznx xsimpleaznx is offline
depends how much performance u want, the amount of money ud spend on basic bolt ons would in the long run be enough to go turbo. or, go nitrous. fastest, cheapest mod i believe most people would agree on. me personally, i couldnt sit around not buying anything for my car so i bought a poormans $125 header til i save up enough for a turbo. no point in spending $250+ for dc etc if ur just going to swap it out, but same can be said for the $125 i spent on a cheapie.
'have learnt a lesson'
Old 05-23-2004, 07:10 PM
TSRyder6's Avatar
well...my goal is around 235whp...so if these things won't give me that much power then TURBO it is!!
Old 05-30-2004, 05:14 PM
dc2_bountyinteg dc2_bountyinteg is offline
you would have to spend alot more than 2200 to make a n/a car have that kind of wheel hp you are just wasting money on all that other bolt on garbage. First get the turbo then slowly buy that other stuff if still not fast enough.
Old 06-01-2004, 12:54 AM
shaunthebadass shaunthebadass is offline
Send a message via AIM to shaunthebadass
i would look into new ignition,work on my fuel system (injectors,fuel pressure reg...) and definatley a skunk 2 intake manifold will net you some good horsepower and really nice throttle response if put together with a full cat back exhaust(greddy evo or skunk 2), header and cai
Old 11-11-2004, 09:01 AM
Fuxwitus 1st Fuxwitus 1st is offline
i beat guys with the usual upgrades all day (headers, intake, exhaust). infact last week i burnt a turbo porshe making pssssssss psssss psssss sounds.
if you really wanna do your car a favor get the energy suspension motor mounts kit and upgrade your axles. Strengthen your engine groundwire with a nology power strap ( much better ground). I just also added the nology hotwires and silverstone spark plugs which together add 137 % more spark than regular plugs and wires. O and to almost complete your perfect ignition i recomend the Msd modified distributer cap and Msd HVC external coil with the Msd HVC 6600 ignition box. I installed an Exedy full racing clutch that sorta looks like a stock clutch.Thats basically my set up. Oh and i removed my spare tire / jack/ passenger seat. i have a stock exhaust, stock headers, and a cheap obx intake.
Old 11-11-2004, 01:46 PM
integrawhat integrawhat is offline
Send a message via AIM to integrawhat
Re: Re: Can I make my Integra fast without Turbo or Swap?
he said its a GS-R B18c1 it has 180 bhp stock
A.K.A. GOT WIDE
darton 84mm MID's ls stroke 2.0l GS-R
pnp head with full skunk2 pro series valve train
and pro1 cams
custom divided top mount w/garrett gt4094r
not stoping till i hit 750hp to the wheels
this aint your mom's car so DONT F***ING TOUCH IT
