Old 05-22-2004, 01:08 PM
MR2_Lancer MR2_Lancer is offline
Send a message via AIM to MR2_Lancer
squadron white putty?
is this putty any good? picked up 2 tubes of it for 4 bucks jus to try it out...
GreG
Old 05-22-2004, 01:12 PM
geofroley geofroley is offline
Send a message via AIM to geofroley
From what I've heard around here Squadron White is a really good putty. I've seen some pretty awesome body styles by people using Sqaudron.
customcrx's Avatar
customcrx customcrx is offline
yes it pretty good putty it is all i use and i works great just before u go to apply it get ur finger wet it cuts down on sanding time and the amount of putty u use
Old 05-22-2004, 01:25 PM
freakray freakray is offline
AF Modelrater
Re: squadron white putty?
I'm not a big fan of Squadron white, I have found it to be too coarse.
Squadron green on the other hand I really like.
AF User Guidelines
Old 05-22-2004, 02:50 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I hate squadron white. All I end up with is a mess and a big headache. The fumes are horrible.
-Mike
Old 05-22-2004, 04:05 PM
935k3's Avatar
935k3 935k3 is offline
If you want to do body sculpturing and reshaping you really need to use a two part(putty and hardener-catalyst) putty. It's the only type that will not shrink over time. If you use Squadron white look at it 6 months from now and you will be sorry you used it. Two of the best are Dynatron Puttycoat and Evercoat brand. You have to by them at a Automotive paint supply shop. Dynatron is so smooth it can be polished to a shine that matches the plastic, and it feather edges very well.
Old 05-22-2004, 04:07 PM
935k3's Avatar
The people that say it is so good have not tried anything better, Green or white it's some of the worst stuff out there, in a category with Testor's so called primer.
Old 05-22-2004, 04:08 PM
customminatures's Avatar
customminatures customminatures is offline
Send a message via AIM to customminatures
use the bondo spot and glaze putty
people say its no good but i have never had a problem with it!
--------------BRINGIN MINI AND SPORT TRUCKS TO AF!!---------------
Good quote_ turbo monster-"An artist is one who is critical of his own work. An Asshole is a failed artist who is critical of other's work."
(explains everything!)
Old 05-22-2004, 04:11 PM
mike@af's Avatar
Dont listen to Matt.
-Mike
Old 05-22-2004, 04:30 PM
935k3's Avatar
Re: Re: squadron white putty?
It is ok for very small holes,seems or grooves, but anything bigger needs a two part putty. Bondo makes a good one called Bondo Ultimate, it has a blue label and is a finer grade than regular(gold label)Bondo. The two part putties dry as quick as 5 minutes.
Old 05-22-2004, 05:05 PM
bvia's Avatar
bvia bvia is offline
3M's Piranha Putty is also a good 2-part product.
hth,
Bill
