Go Back   Automotive Forums Car Chat > DeLorean > DMC-12
Old 05-22-2004, 12:47 PM
hifeverz hifeverz is offline
Red face Delorean Power Drain
RE: '81 Delorean
When last running my car would drain the battery after sitting in the garage for less than a week. I was going to install one of the products called "Priority Start" that would alleviate this dilema of a dead battery. However the drain would still be there. Any hints on where to correct this drain of juice???
Thanks,
Hz
Old 05-27-2004, 10:51 PM
SpookyReuben SpookyReuben is offline
Send a message via AIM to SpookyReuben Send a message via MSN to SpookyReuben Send a message via Yahoo to SpookyReuben
a running electrical system most likely i.e. lights left on etc.
Old 06-30-2004, 11:40 PM
DMC12's Avatar
DMC12 DMC12 is offline
DeLorean Guy
Re: Delorean Power Drain
Have you had this problem in the past? It could be a dying alternator which fails to charge the battery properly, casuing the battey to fail and lose charge while sitting. My D can sit for 6 months & start right up. Also, look at the connections to the alt - they can be corroded. Also the door lock box could be stuck "on" causing a drain.
SOLID! crew (circa 2002).
DeLorean moderator.
