Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-22-2004, 11:44 AM
swamper swamper is offline
96 Brake light indicator / bulbs replaced / tail lights out
The brake warning light comes on after ignition, when brake pedal is pushed to put car into gear. Replaced ALL bulbs and fuses. Also, the dome light wont work.. Read about the bulbs, brake pads, fluid, and relay box, but haven't gotten past bulbs yet. Any suggestions?
Old 05-22-2004, 05:51 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: 96 Brake light indicator / bulbs replaced / tail lights out
swamper,
Check the level of fluid in the master cylinder before doing anything. When it drops to the "min" line or just below, the light will come on. If it is low, add DOT 3 brake fluid till it is at the "max" line.
Mike
