Old 05-22-2004, 09:24 AM
cody911911's Avatar
cody911911 cody911911 is offline
amp question
I have 3 150 rms 400 watt peak 10" rockford subs. I am having trouble finding a mono channel amp for them because most would overpower them and then burn them out....Is it possible to use 450X1@4 ohms and then loop my 3 speaker wires together sending 150 rms to each or is this impractical? Rather than paralleling and having 1.33 ohm which is hard to find a 1 ohm stable amp that is not expensive. Any suggestions?
1st rule of drinking and driving.......you gotta have a beer.....
Old 05-22-2004, 10:01 AM
cody911911's Avatar
Lanzar amps are they any good I found a 4 channel running 125 rms and 300 max per channel....
Old 05-22-2004, 11:34 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: amp question
Like I told you before, 50 watts over the limit won't burn up the speaker unless you're a complete retard, in which case you would burn up the speaker with an amp rated at exactly 150rms anyway. Get the JBL
Lanzar is bargain bin trash, especially their lower lines, and powering 3 subs separately on a 4ch amp is straight up ghetto
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-22-2004, 12:16 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
Re: amp question
well finding an amp that does 400-500 watts at 4 ohm will cost you ALOT, my suggestion is to get the HIFONICS BRUTUS BX500D, it makes 500 rms at 1 ohm, its a real value it only cost about $175 (shipping included) on ebay, i am going to get the higher models tho, probably the BX1000D/BX1500D
and overpowering your subs a lil won't hurt, just be smart about it, dotn do obvious things like turn the gain all the way up, or the bass boost, or put it in a rediculously sized ported box, i had an alpine type R before, i used 400rms on it, but then again the gain wasn't all the way up, and i know that the type R can take more than 300rms
Old 05-22-2004, 05:01 PM
sr20de4evr's Avatar
Re: amp question
Forgot about this when I responded earlier.....
Not only is this impractical, it's simply impossible. There are only 3 ways to wire your speakers together, no more, no less.
1 - Wire them together in parallel, this will show the amp a 1.33ohm load and you'll get the 1.33 ohm power going to the set, 1/3 of which will go to each sub
2 - Wire them together in series, this will show the amp a 12ohm load and you'll get the 12ohm power going to the set, 1/3 to each sub.
3 - Wire them individually, this will require 3 separate amps. You could use 3 channels of a 4ch amp, but that is so insanely ghetto I don't know where to start.
I don't know what you're talking about "loop the 3 speaker wires together", when you attach the speakers together you are either attaching them in series or parallel, that's the only way you can possibly wire multiple electronic devices together. Depending on which you choose (series or parallel), the final impedence is either the sum of the individual impedences (series), or the inverse of the sum of the inverses of each individual impedence (parallel).
'01 Black Sentra SE
'05 Silver WRX STi
Old 05-22-2004, 11:15 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
get a big class D amp ....... you can easily double the woofers RMS ratings if you set the gains right
