Old 05-21-2004, 09:34 PM
churley churley is offline
Angry Cooling Fans don't turn on
My cooling fans are not working and I've already replaced the relay and the temperature sensor. I also tested the fans directly from the battery and they work fine. Does anyone have any other suggestions. Thanks for the help.
Chris
Old 05-22-2004, 01:25 AM
GTPCatz GTPCatz is offline
Banned
Re: Cooling Fans don't turn on
what does your temp get up to?
fans wont turn on until like 210 degrees
Old 05-22-2004, 07:23 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Let your car run at IDLE for 15 minutes. The radiator fan should turn on within that time frame.
Check this out. It might not be specific for your car but you'll get the idea on how most radiator fan works.
www.thirdgen.org/tech/cool8dual.pdf
Old 05-23-2004, 03:00 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
if you have a stock PCM the fans are supposed to start either when the engine temp reaches 210 or when the AC/Compressor is engaged. If the temp needle in your dash get's all the way up to where the red hi temp warning light comes on then you might have a PCM problem. IF you replaced the Relays and temp sensor, tested the fans directly to the battery then the most probable cause is open circuits at the PCM. I do not remember correctly but either the PCM provides 12VOlts to the relay or grounds it to start the fans and if this circuit open up the fan will never start even tought the PCM might tell you that is trying to do so.
