Go Back   Automotive Forums Car Chat > Buick > Regal
Old 05-21-2004, 08:59 PM
LuvGrnFrogz LuvGrnFrogz is offline
Send a message via Yahoo to LuvGrnFrogz
Angry 1991 Buick Regal 3.1 fan/overheat problem
I am writing to help my friend find out what is wrong with his car. He has a 1991 Buick Regal 3.1. He just replaced the engine and after he replaced it everything works but the fan. They think they have it narrowed down to a computer problem because a relay is bad inside the computer that goes to the fan. They are just wanting to know if anyone else has had this problem, has a wiring diagram for a 1991 regal, or have any suggestions before they replace the computer.
Thanks!
Old 05-23-2004, 05:04 AM
public's Avatar
public public is offline
Being that the car is this old you may wish to buy a universal relay (about $10) and wire the fan via the relay to an accessory output on the fusebox. Some of the outputs are controled by the key switch. This way the fan would come on anytime the engine is running. This is commonly done here in Florida; due to the heat the fans are always on and burn relays rather often. Good Luck.
Old 05-24-2004, 02:50 PM
Re: 1991 Buick Regal 3.1 fan/overheat problem
PROBLEM SOLVED.
turns out the computer wasn't resetting correctly, they finally got it to reset and now everything works fine
Old 05-30-2004, 04:17 AM
public's Avatar
Cool. No pun intended.
