Old 05-21-2004, 08:39 PM
pro3racer pro3racer is offline
intake(little newb)
i heard that your not really supposed to drive a car with a cold air intake, because water can get into you intake, which could get into your engine and do some serious damage(scoring, same kinda when you put water in your oil, lol).
Old 05-21-2004, 08:44 PM
joebowlr21 joebowlr21 is offline
Send a message via AIM to joebowlr21
That is why a little thing called a bypass adapter was invented.It is a small divider type device that you place on your intake tubing which helps keep moisture out of the intake tube.
Old 05-22-2004, 03:16 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
Re: intake(little newb)
those things are prettymuch useless unless you're driving through puddles over 8" deep... you won't suck in enough water to hydrolock your engine unless your intake is completely submerged.. if cai's were so dangerous.. would that many people be using them?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 05-23-2004, 01:32 PM
matt11583 matt11583 is offline
yea the odds of much water getting into your intake is next to none. the only times ive seen a problem is when i go 4 wheelin in my uncles jeep. we flooded it once. lol. unless you go through lilttle creeks or huge puddles, you will be fine.
