Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-21-2004, 05:32 PM
1997Camry 1997Camry is offline
Question '97 Gas pedal sticks from time to time
Is there anything I can do to fix the sticking gas pedal from time to time? It usually occurs after I stop at a red light, then it's like it's stuck, but when I force it down (about 3x normal force), it'd go down, as if it just broke free. It doesn't cause any problems but I don't like the sudden surge forward I get when I force the pedal down. It happens about 2-4 times a month.
Old 05-21-2004, 07:03 PM
calvic calvic is offline
Re: '97 Gas pedal sticks from time to time
Sounds like a dirty throttle body. Butterfly sticks in the goo. Just remove air intake hose and squirt it down with carb. cleaner, contact spray etc. and wipe it clean. Be sure to get back side of butterfly. Common problem! Good Luck JJ
1988 Camry LE
4 cyl Auto
335,731
1994 Volvo 940 Turbo
1992 Dodge Cummins Turbo Diesel
2006 Mustang GT
Old 05-21-2004, 09:11 PM
Does anyone hav a picture, diagram, or a general description of the "air intake hose" area? I just needed to know what to look for. Already have the carb cleaner. Thanks.
Old 05-21-2004, 09:53 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
1997Camry,
Try this link. It's for a V-6 but it is exactly the same information for an 4 cylinder and gives great detailed instructions on how to clean the throttle body.
http://www.4x4wire.com/toyota/mainte.../throttle_body
Mike
Old 05-21-2004, 10:10 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Try this:
http://www.4x4wire.com/toyota/mainte...throttle_body/
Old 05-21-2004, 10:11 PM
AF -Advisor
1997Camry,
Sorry, I'm having trouble getting the link to work. Don't know what's wrong. Just go to 4x4wire.com and run a search for "throttle body cleaning" and it should be the first item that is listed. Click on that. I was able to get to it that way.
Mike
Old 05-21-2004, 10:12 PM
Brian R.'s Avatar
Resident Chemist
I believe we are thinking along the same lines...
Old 05-21-2004, 10:13 PM
AF -Advisor
Brian R has it correct. Thanks Brian.
Mike
Old 05-21-2004, 10:16 PM
Brian R.'s Avatar
Resident Chemist
You're welcome. I remembered that site from a previous topic, but had a hard time finding it.
Old 05-21-2004, 11:36 PM
Brian R.'s Avatar
Resident Chemist
BTW, I checked and the only difference between my link and yours is a forward slash at the end.
Old 05-22-2004, 03:25 AM
thank you guys, that's really helpful!!! This is my first time trying to find info on my car (dont' know why I never bothered to do this before, DUH!), but I'm getting lots of info in just a few days. You're awesome!
Old 05-22-2004, 11:06 PM
ice745 ice745 is offline
AF -Advisor
Re: Re: '97 Gas pedal sticks from time to time
I hate to be an ass, lol, but the difference is one's 'V' is capital, and one is lowercase in '30_V6'. In html capitalization makes a big difference.
Old 05-23-2004, 12:44 PM
AF -Advisor
ice745,
Thanks for the correction.
Mike
Old 05-23-2004, 07:07 PM
Brian R.'s Avatar
Resident Chemist
check
(makes me sorry I brought it up.. )
Old 05-26-2004, 06:57 AM
don24mac don24mac is offline
This sticking throttle has happened to me in two different cars. A 90 Camry and am 89 Camry. Both times, it was the butterfly valve actually contacting the throttle body and getting stuck. Check to make sure the adjustment screw outside the throttle body is what is actually stopping the butterfly valve when it's closed. If it's contacting the inside of the throttle body, it will eventually cause a groove, too.
BTW, the 90 camry did have a slight groove in the throttle body. But after the adjustment, everything ran fine, with no more sticking throttle. The 89 was fixed too, but didn't get the groove.
