Old 05-21-2004, 03:46 PM
Fewman Fewman is offline
Send a message via AIM to Fewman
enclosure material question
OK, I've decided to build a new enclosure out of wood... Any tips? Also, I need to know what type of wood (and depth) to purchase. Thanks!
Old 05-21-2004, 06:38 PM
lkailburn's Avatar
lkailburn lkailburn is offline
Send a message via AIM to lkailburn
Re: enclosure material question
enclosure.... FOR WHAT?!
be specific with what you are trying to build so that people can help you out.
most people use 3/4" MDF to build audio enclosures in
Old 05-21-2004, 06:42 PM
LOL... it's for a subwoofer...
Old 05-21-2004, 11:34 PM
lkailburn's Avatar
i take it you want to build a sealed box for it then?
3/4" mdf,wood screws, and some silicon sealer or liquid nails should do the trick. just make sure you match up the volume with what the sub recommends
Old 05-22-2004, 12:22 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
if you use silicon, make sure it's dry before you throw your subs in. The gases they give off can screw up your surround.
Empty Pockets Racing Member #1
Old 05-22-2004, 12:59 AM
Here' is my diagram: i end up like .8 cu inches short of 1 cu foot, do you think that's sufficient? Thanks...
Old 05-22-2004, 04:37 PM
1gspot's Avatar
1gspot 1gspot is offline
Send a message via AIM to 1gspot
it doesnt sound too bad but here is some advice. I would make the box bigger if at all possible. One thing i have a feeling u are forgetting is the thickness of the wood you are going your use 3/4 of an inch may not seem like much now but when its on all sides you are really gunna loose some volume. to everyone ALWAYS ALWAYS FIND VOLUME INCLUDE MATERIAL THICKNESS. However if you have already thought of that an u are only .8in short that is relativly insignificant but most subwoofers recommend a minimum of 1 cubic foot, so you are a lil short of the minimum, like i said if at all possible go bigger
Old 05-22-2004, 11:25 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the other thing people forget to do is subtract the volume of the woofer basket.
Old 05-22-2004, 11:54 PM
mjshort18 mjshort18 is offline
i had my subs in a 4.6 cu ft box and then i made 2 new boxes that were about 1 cu ft a peice and my subs sounded so much better. now they are louder and have better sq.
Old 05-23-2004, 12:21 AM
I have included the thickness of the wood, but I didn't think about the depth of the subwoofer... Will that make much of a difference?
Old 05-23-2004, 07:04 PM
GScivic7's Avatar
well, a subwoofer basket is pretty big, you may be able to compensate by using polyfill though.
Old 05-23-2004, 09:54 PM
How much polyfill should I use? Where do I get this stuff?
Old 05-23-2004, 10:10 PM
GScivic7's Avatar
you can get it at a fabric shop. It's just the filling they use for stuffed animals and such. It's just polyester fibers I believe. Hence the name POLYfill, I think lol. Anyhow, general rule of thumb is about 1lb for every 1 cubic feet.
Old 05-23-2004, 10:25 PM
Audio Guy
most subs have their basket displacement on their spec sheet
Old 05-24-2004, 03:05 PM
What exactly does the polyfill do? If I use a full pound, will that increase my sq dramatically? Or should i use less than a full pound... more if my box is too small? I guess my real question is, if my box falls shorter than expected (EG I cut something wrong) will the polyfill help the sq enough to make it sound like I have a full cu foot?
