Old 05-21-2004, 01:59 PM
Fenixfire077 Fenixfire077 is offline
Send a message via AIM to Fenixfire077 Send a message via Yahoo to Fenixfire077
engine swaps
hey, i am interested in throwin in a bigger honda engine into a delsol, and turbocharging it. just so i know what my odds are, how big of an engine can i go with, and can it be turbo? for instance could i throw in a turbocharged k24a?? or is that wayy too big?
Old 05-22-2004, 12:03 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: engine swaps
You're going to have to do a lot of custom fabrication to even fit a K-series into the Del Sol in the first place. Stick to a B-series swap. Tried and proven, lots of aftermarket support, and aleady have support for swaps. I would swap in a B18 flavor and turbo that.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 05-22-2004, 06:17 PM
b16a3sol b16a3sol is offline
Re: Re: engine swaps
ditto
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 05-22-2004, 06:23 PM
gotchya. would you guys recommend www.raceeng.com for the engine parts? do they have a decent reputation? also if i did a b18 swap, i could stick with the same tranny?? or no?
Old 05-24-2004, 01:19 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
Re: engine swaps
if its a b-sereies hydro tranny then yes you could keep it...but a full swap is going to come with a tranny anyways so it wouldnt matter..if i had a choice id go GSR unles you plan on running very high boost ammounts then a LS might work better for you.... And yes stick with a B-series...dont stray away from proven results ! And I would again opt for the B18 and would utilize rather a hybrid T3/T4 setup..or a custom TD04 setup..but that depends on if your building the set up yourself or buying a bolt on kit....rather you were going to be building your internals would also play a factor in turbo selection ... as far as were to look for your swap....
www.hmotorsonline.com
i did not nor have not used them personally as of yet..but i have many peoples that have and there one of ..if not the best to deal with in my opinion
Old 05-24-2004, 01:29 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
I've ordered from Hmotorsonline.com... good communication and well informed. The engine came from them with broken sensors, but uppon closer inspection, they included extras with my engine to replace the broken ones... so I was very satisfied.
Honda Enthusiast
