Old 05-21-2004, 09:33 AM
bennybenster bennybenster is offline
Send a message via AIM to bennybenster Send a message via Yahoo to bennybenster
Car is idling funny...need help???
Hey guys,
I've been noticing that once my car warms up, it's starts to idle funny. It would go from around 900 rpms then drop to around 500 then back to 900 then 500...etc etc...
Then when I turn on my headlights, it goes from 500 to 300...etc...
And it just keeps going and going...sometimes, it almost feels like the car's gonan stall...
So, what could be causing this?
BennyBenster
Old 05-21-2004, 09:39 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Car is idling funny...need help???
any check engine light?
it's hard to tell unless you give us more info...
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 05-21-2004, 10:06 AM
crx91's Avatar
crx91 crx91 is offline
could be ur alternator.check that.
Old 05-21-2004, 10:21 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
i agree, sounds like your alt is not charging correctly, get yourself a voltmeter and measure it while the car is on, the reading should be around 14-14.5v
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-21-2004, 12:15 PM
No check engine light...
I'll check the alternator and see if that's it...thanks!!
BennyBenster
Old 05-23-2004, 06:59 PM
Ok, so I bought a volt meter from radio shack and tested both the battery and alternator. Battery is measuring at 12.0 volts and the alternator at 14.0 volts. So it looks like those two are ok. I also checked all the plugs and only one of them wasn't gapped right. So I went ahead and gapped it to .039. The rest were gapped fine. Also, I checked the cap and rotor and those looked good too. But the car is still idling weird. Any other suggestions??
When I got the swap, the plugs, cap and rotor were all replaced. The only thing that wasn't replaced was the spark plug wires. Could that be it? I also checked the aif filter and it looked pretty dirty. I went ahead and replaced that too.
I have an appointment with the ref this Tuesday and I don't want anything to go wrong. I hope this doesn't cause my car not to pass. Any other suggestions is appreciated. Thanks!
BennyBenster
Old 05-23-2004, 10:37 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
is it surging...if the rpms are surging back and forth it could be a bad iac motor..common on a honda
Old 05-23-2004, 11:18 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
i think a friends was doing that before and it was something to do with like air fuel leak. i could be wrong but they tighten some bolt up like that and it stop jumping back and forth
Old 05-27-2004, 03:46 AM
recycle_me's Avatar
recycle_me recycle_me is offline
Send a message via ICQ to recycle_me Send a message via AIM to recycle_me Send a message via MSN to recycle_me Send a message via Yahoo to recycle_me
it could be your ignitor in the distributor going bad i had one do that and replaced the ignitor and ever thing cleard up its like 40 buk form honda you may find it cheaper at autozone or some place like that
Old 05-27-2004, 07:15 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
also, check grounds... ignition, battery, etc. Mine did that, got battery light... ground was loose... it's an ongoing project though...
