Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-21-2004, 09:01 AM
James20VT James20VT is offline
Question Hot starting problem
We have a 1998 3.0 V6 Camry which has difficulty starting when the engine is still hot.
When you turn it on the revs dip too low and it cuts out. If you slightly rev it, it will keep running but die when you let off. If you give it full throttle then this normally sorts it out. Any ideas?
Cheers.
Old 06-23-2004, 09:24 PM
gelcol gelcol is offline
Re: Hot starting problem
check some hoses if there's a leak buy puting soap and water on the spraybottle and ask someon to crank it to see wheres the air leaks dont spary on the elect.wires just hoses.
Old 06-23-2004, 10:08 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
The intake system could possibly be clogged or obstructed, fuel isn't reaching the block, bad battery connections, loose or faulty connections at coils or alternator, or vacuum leak.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 07-09-2004, 11:27 PM
dtm03 dtm03 is offline
i had the same type of problem. the dealer fixed it with an idle speed control vavle. it cost me about 400 bucks, 5 days after the 1 year warranty was up it took a crap again. i found a local shop that sells rebuilt ones for 95 bucks, and it has a lifetime warranty. its been about 2 years and no problems. i know it kind of late, but let me know if you want their phone#
