Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 05-21-2004, 07:48 AM
eejad eejad is offline
Send a message via MSN to eejad
Idle problem with 1.8 SOHC
That's for all the Protege 90-93 with the 1.8 SOHC owners. I owned a 323 LX last year with a 1.8 SOHC and now I have a Protege with the exactly same mechanical parts so I know them pretty well . The problem is those two cars both had a strange idle.... It's not very easy to explain... Every time the clutch is released, before going back at a normal ~750rpm idle, the engine tempt to go off with an rpm going under 350... I have notice that it's a amplified when it's raining... I know that it should sound like a problem connected with the ignition system (plugs, wires, distributor, etc...) but everything is brand new. The exhaust, battery, alternator, air filter, oxygen sensor are in perfect shape, I don't have any trouble code in the computer. Maybe it is a problem with the gaz pump or a vacuum leak? I'm wondering if one of you guys could help me, it would be really appreciated!
i apologise about my poor writing, i'm not used to do it in english
Old 06-10-2004, 04:30 PM
Pakeboy2's Avatar
Pakeboy2 Pakeboy2 is offline
Send a message via AIM to Pakeboy2
Re: Idle problem with 1.8 SOHC
Check the engine to frame ground wire...most times they are corroded...
1999 Chevy Tahoe LT 4 dr.<---got flooded out/totaled
Now we have a 1999 Chevy Suburban LT, same color and
interior as the Tahoe, just 22 inches longer, has the 3rd seat and a BIGGER gas tank
1995 Honda Passport 2 whl dr.
1992 Mazda Protege DX-5 spd.
2005 Keystone Outback 21RS
~~~HAWAIIAN STYLE~~~
cardomain.com/memberpage/621985
cardomain.com/memberpage/643906
weedlesswillie.com
