Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-21-2004, 02:25 AM
Gerald Evans Gerald Evans is offline
Question oil
I don't believe in 'trick' oil. 5w30 is five weight oil with parfin thickners in it. problem is 'thickners' are not oil.
I use only 30w Valvoline oil in all my vehicles. 96 Astro van v6 from day one nothing but 30w oil. Jiffy lube said 'you may void warrenty' I said if 30w valvoline hurts the engine, I'll eat it. Van now has 145k and never used one drop of oil. Only problem since new was belt tension idler.
Now someone tell me why syn oil is better. Thinking about using syn in Saturn. Tks
Old 05-24-2004, 11:09 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: oil
go visit bobistheoilguy.com for more then anybody should know about oil
Old 05-30-2004, 06:48 PM
Lucas1 Lucas1 is offline
the main difference between regular oil and synthetic, besides the obvious chemical differences, is that synthetic oil lasts much longer. synthetic oil does not breakdown as fast as regular oil. otherwise it is similar. Mobil 1 synthetic, in my opinion (and in GM's opinion) is the best oil available. the oil is more expensive, but you can go longer between oil changes (just be sure to check your oil regularly, because saturns do burn oil). as far as viscosity, 5w-30 is what saturn recommends. they recommend it for a reason, at lower temperatures it acts as a 5W oil, very thin, good for cold starts, the oil is easy to circulate through the engine. at higher temperatures it acts as a 30W oil thicker and better at dissapating heat. oil also has a great impact on fuel economy, the thinner the oil the better the gas mileage, it really does make a noticeable difference. i bet your van did not get very good gas mileage....if you read the owners manual that came with your car, its all in there
