Old 05-21-2004, 02:04 AM
2crunk's Avatar
2crunk 2crunk is offline
Question Removing the amber parking lamp reflectors
I have a Dark Red '03 GT and am customizing it with silver and chrome colors inside and out. I was wondering is there any way to take out the orange reflector in the headlamp and replace it with a chrome one or do i need to replace the entire headlight?
Old 05-23-2004, 01:08 AM
2crunk's Avatar
Re: Removing the amber parking lamp reflectors
anybody............?
Old 05-23-2004, 01:24 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
You shouldnt do it because the headlights are sealed, but thats what I did for my 92 GT. You have to carefully(very carefully!) "break" the front section off the headlight assembly. Then, one again break the amber insert out. Then use a small, carefully placed amount of clear silicone to reseal them 100%. While your in there use the headlamp haze fix in the tech section to clean em up real good.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-23-2004, 04:12 AM
2crunk's Avatar
When you say "break", do you mean take the glass part of the headlight assembly from the plastic molding on the back?
Old 05-23-2004, 03:00 PM
Well they used some type of a hard silicone or something from the factory to put the lens on the headlight assembly. Thats where it needs to be seperated from. I believe its like a grey in color, you'll know. Like I said be careful though cause you can crack the lens easy. I used a razor to weaken the factory glue, which then made it pry apart a little easier. You might wanna get a junked one from a salvage yard and practice first before you bust yours up.
Old 05-23-2004, 03:29 PM
2crunk's Avatar
Alright, thanx.
Old 05-23-2004, 03:35 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
a hair dryer will losen up the glue holding in the reflector
Old 05-23-2004, 04:29 PM
2crunk's Avatar
Yeah, i thought about that. One guy told me to put the entire headlight in the oven, but i thought that was a little drastic.
