Old 05-20-2004, 11:22 PM
94sportsedan 94sportsedan is offline
2000 Grand prix coolant light low???
OKay 3.8 Liter, 71k miles. Everytime I start the engine cold the low coolant light is on until driving for about 10-15 minutes. Goes off stays off until engine cools down. I have checked the radiator and verified the coolant is a cup or 2 low. I usually drain the coolant back into the radiator from the overflow bottle which never gets low or anything but will always be at the same mark. So it seems the radiator will expel the coolant back to the overflow bottle when it heats up but doesn't suck enough back in when the engine cools down? thus causing the light to go on and off. So why?
Old 05-21-2004, 06:02 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 2000 Grand prix coolant light low???
Check and make sure that the tube running to the coolant bottle isn't partially blocked. Sometimes the coolant will deteriorate the tubing and will only let coolant flow one way. Second, your radiator cap may be at fault. If it doesn't hold as the engine cools it will not allow the system to create a vacuum to draw the coolant back into the radiator. Finally, check to make sure that the hose inside the coolant tank is connected and that there no holes in it. This too can cause the system not to draw the coolant back into the radiator.
Old 05-21-2004, 07:23 AM
Thanks for quick reply. I was able to blow throught the hose no problem. 2nd there is no hose inside these bottles. 3rd I will try a new cap. Thanks
Old 05-21-2004, 12:51 PM
GTPCatz GTPCatz is offline
Banned
I would say your water pump is going out.....what are you temps running at?
Old 05-21-2004, 03:11 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Have you bleed the air out of the system???......that could be your problem.Get the car to operating temp with the cap off then top off the radiator put the cap back on then make sure the bottle has colant in it then bleed the system.....~Larry~
ClubGP Member 6530
Since 2001
Old 05-21-2004, 05:11 PM
Well I let the engine heat up and I have been opening the bleeder on the thermostat. The temperatures on the highway run right on the 1/4 line and a bit higher on the highway. Could my problem be a cracked intake manifold? I don't think a headgasket is a factor as my fluid doesn't lose or no tailpipe smoke. I bought a cap and gonna try that today.
Old 05-21-2004, 05:23 PM
BIG-L's Avatar
If you have a cracked intake then you would be getting water in the oil....also you would have a vacuum leak and it would not run very good..do you have any leaks under the car from coolant??There is a weep hole under the shaft of the water pump that will leak coolant once the bushing goes out...~Larry~
Old 05-21-2004, 09:58 PM
Moser28 Moser28 is offline
I have a 99 GT with 98k on it and my reservior loses about a cup of coolant every two weeks. The low coolant light flashes and I add colant and the light goes off. I see NO LEAKS anywhere. Doesn't run hot. I was thinking about changing the thermo, cleaning out the reservior and the line going to the radiator and flushing the system. Do you think this would solve my problem? Thanks.
Old 05-27-2004, 05:51 PM
sheekoGTP sheekoGTP is offline
Hi, I had same problem with My 2000 Grand Prix GTP, The Low Coolant light was coming on every 10 to 15 minutes. I took to the dealer and replaced the Coolant sensor. The sensor was leaking the and causing the problem to light come on the Dash. After replacing the Coolant sensor, everything works fine now. I paid almost $282. Which include diagnostic check,coolant and rediator flush. I have only 42,000 miles on my car. Since then my car is running perfect and the gas milage is about 19.0 MPG in city. Which is very good.
Old 06-02-2004, 10:16 AM
Joelb251 Joelb251 is offline
Send a message via ICQ to Joelb251
loss of coolant
its hard to say what it could be, but I know with the GM 3.1, 3.4, and 3.8L engines one of the most common issues it has is that the intake manifold gasket deteriorates and begins to leak. I have seen them fail on cars with 15,000 miles, but that causes it to leak oil, not coolant.
Old 06-02-2004, 12:14 PM
A-ROC A-ROC is offline
i have a 1998 Grand Prix GT. After 20 minutes of driving the tempeture climbs to 100 at idle..is this normal?
Old 05-14-2005, 02:50 PM
MDSKR MDSKR is offline
Are you loosing ant coolant? If you are cheak you oil and manke sure it isn't going in the crankcase. The Plantum on the 3800 engine will melt where the EGR valve tube goes and allow colant to go into the crankcase or the intake. If this has happen to you car replace the intake ASAP, you might want to also replace the crank and rod bearings also. I have replaced several of the plantums and latter had the rod bearing go out.
Old 05-15-2005, 06:01 PM
GTPgirl's Avatar
GTPgirl GTPgirl is offline
Send a message via ICQ to GTPgirl Send a message via AIM to GTPgirl Send a message via Yahoo to GTPgirl
Re: Re: 2000 Grand prix coolant light low???
I get about 21.4 MPG city, and that's with me raising hell in my car.
GTPgirl
Black 1998 Camaro - currently driving
Black 1999 Grand Prix GTP - burned March 2008
Plum Crazy 1970 Dodge Challenger - work in progress!
