Old 05-20-2004, 05:42 PM
salbrent salbrent is offline
Programming Instructions for 02 Olds Intrigue
I purchased second keyless remote from the web and need programming instructions. I checked the archives first before posting
Thank you
Brent
Old 05-21-2004, 11:08 PM
dragon459 dragon459 is offline
Send a message via Yahoo to dragon459
Try this:
Sit in the drivers seat and close all doors
press and hold the unlock button and insert and remove the key 3 times, on the 3rd time, leave the key in the ignition.
press the lock & unlock buttons on the remote for 12 secs
Repeat for ALL remotes ( up to 4)
Remove the key for the ignition
That should work
Old 05-22-2004, 10:47 PM
Re: Programming Instructions for 02 Olds Intrigue
no luck
might because has Pass lock system
Old 08-13-2004, 12:29 PM
Thank you. I got the remote programmed.
same instructions as you provided except I wait for the chimes then press the lock the unlock button and removed key.
Works like new !
Thanks
Brent
