Go Back   Automotive Forums Car Chat > Buick > Century
Old 05-20-2004, 10:18 AM
cosmo12550 cosmo12550 is offline
1990 Century Stalling and starting problems
Hello,
I am having a few problems with my 1990 century. The first problem is when you try to start the car, it cranks for a good 10 seconds then will start. once it's started it then idles very low. I believe it should idle a little higher while warming up. It also will stalls when you come to a stop, or it will jerk forward slight at a stop. Also when you are driving, it seems to either loose spark or stops getting gas. Am not sure how to tell the difference on the last problem, Any help would be appreciated.
Thanks
Cosmo
Old 07-09-2004, 01:32 AM
MelinaCougar1999 MelinaCougar1999 is offline
hey i dont know if it will help much but i had the same problems with mine it turned out to be a lose vacume hose id go ahead and look into that just check all your hoses and make sure theyre all pluged in all the way
