Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 05-20-2004, 06:45 AM
wwh975 wwh975 is offline
STP Fuel System cleaner
I just read some of the threads that said that STP fuel system cleaners would cause the dreaded sludge problem. Is this true? It hought the cleaner helped clean all the parts. THanks.
Old 06-03-2004, 05:40 AM
rcs426 rcs426 is offline
Re: STP Fuel System cleaner
no not changing your oil at 3000 miles is the only thing that will cause sluge synt.oil is best
Old 06-15-2004, 11:10 AM
rod2envy rod2envy is offline
Re: Re: STP Fuel System cleaner
Hi,
I have been hearing alot of bad things about this oil sludge, I just bought a used 98 Durango with like 92K miles on it, and this is starting to trouble me, is there anyway to eliminate any kind of sludge already built in the engine by previous owners? I cant undo what they did but wouldnt want to have to pay for their careless maintenance. Thanks in advance for the help.
Damian
Old 11-25-2004, 10:11 PM
john4.7 john4.7 is offline
synthetic oil isn't necessararily better than regualar oil. I asked a mechanic about it and he said synthetic is only better if you don't plan on changing it every 3000. Synthetic simply doesn't break down as fast as conventional oil and it doesn't reduce friction any better than a good conventional changed regularly. That's what I heard anyway.
Old 11-25-2004, 10:16 PM
Re: Re: Re: STP Fuel System cleaner
To remove sludge you just need to buy some engine flush. You can find it at any auto parts place. You drain the oil, add the flush which is solvent based, run the engine, the drain the dirty flushing solvent and refill with oil.
