| Let's get Technical! Discussion for hardcore in-depth motor heads! |
I Just Did A Motor Swap In My 92 Civic Hb. Put A D15b In It Finally Got It Running Right After 3 Weeks! And There Is A Ticking Noise Coming From The Head Any Ideas What This Could Be?
Re: Clicking Noise?
could just be your spark plugs.. are u using platinums?
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
could be your sparkplugs or your valves. does the clicking sound vary depending on your rpms?
Re: Clicking Noise?
id say valves, did you check them after you put the motor in?
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
yea i changed the spark plugs to platinum. and yea the clicking noise does speed up up with rpms, and i havent checked the valves........
Re: Clicking Noise?
well then thats your problem, have them adjusted by someone or get the specs for it, and just do it yourself, its very easy.
Re: Clicking Noise?
yep
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights, 2000 Integra Type R: Totaled
adjust your valves
