Old 05-19-2004, 10:19 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
gears
ok im tryin to find out what rear end i have (if its still stock) i looked on the pumpkin and it says .....K218....can i tell from this?
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 05-20-2004, 01:38 PM
Dober89 Dober89 is offline
Re: gears
What year is your car??? Im asuming its a 10 bolt??
Is there an ID tag attached to one of the cover bolts??
Old 05-20-2004, 03:41 PM
zboom86's Avatar
zboom86 zboom86 is offline
Send a message via AIM to zboom86
Re: gears
is a 10 bolt the same as a dana 60?
Old 05-20-2004, 07:45 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: gears
no dana 60 is different, and yes, just about all camaros are 10 bolt, Z's are posi, most others are open, as for gear ratio, look at your build sheet aka spid label, and look for the three digit code GU#, and post it. well be able to tell you your gear ratio from that.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 05-20-2004, 08:18 PM
Re: gears
Dont forget about the wonderful 9 bolt rear end.
Old 05-20-2004, 09:32 PM
korndogg's Avatar
Re: gears
its actually a 12 bolt and ill look tonight
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 05-20-2004, 10:10 PM
89IROC&RS's Avatar
Re: gears
um...... 9 bolt???? eh as far as a 12 bolt, im guessing were talking aftermarket, in which case theres no way we can tell you, or its a first gen, in which case ill have to do some digging on how to decode those, they might have different codes for the gears, i assumed we were talking third or fourth gen here.
Old 05-20-2004, 10:12 PM
korndogg's Avatar
Re: gears
well what i did yesterday was turned the tire one rotation and counted how many times the drive shaft turned.....it came out to a little over 3 and a half times.....i heard thats a way of telling...
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 05-20-2004, 10:17 PM
89IROC&RS's Avatar
Re: gears
yeah i suppose that could work, kinda a guestumation way, so like 3.50 or 3.73 gears or somethin.
Old 05-20-2004, 10:19 PM
korndogg's Avatar
Re: gears
yeah..somewhere like that....now...im in the middle of puttin the 700r4 in....what gears do you think i should go with?
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 05-20-2004, 10:21 PM
89IROC&RS's Avatar
Re: gears
should work quite nice with what your runnin already, assuming that your guess is right. converter is more a worry for that. stall speed and all. for instance, my 700R4 is shifting weird, and flashing to stall speed in fourth gear, because im running a 2800 stall converter with 2.77 gears. im throwing in a set of 3.27 gears because they are better matched to the stall speed in the converter.
Old 05-20-2004, 10:23 PM
korndogg's Avatar
Re: gears
ok ...the converter that im getting is a 2200-2400 non lockup....
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 05-20-2004, 10:25 PM
89IROC&RS's Avatar
Re: gears
eh, if youre running the 700R4, i would get the lockup, its worth a few MPG and if you wire it to lockup in second gear, its worth a few tenths in the quarter, but using that regularly will burn up the lockup clutch pretty fast. but with gears and a loose converter, the lockup feature is worth its weight in gold.
Old 05-20-2004, 10:27 PM
korndogg's Avatar
Re: gears
ugh i dunno what to get...people tell me to get it and others tell me not to cause i dont need it.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 05-20-2004, 10:31 PM
korndogg's Avatar
Re: gears
oh by the way...its a 68 if i didnt tell you
1968 Camaro 327
{o,o}
|)__)
O RLY?
