| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Subwoofer Box Breaking
I have 2 10' subs in a dual box. I took one of them out today because it wasn’t working and the box on the inside had/did break. Its only little pieces but now my sub doesn’t screw down and have a tight fit. I even tried making new holes but the wood kept breaking. So my question is do I need to get a new box or is this okay. I don’t have a top of the line system so if I loose a little bass its okay.
White 07 STI, Bone stock for now |
Re: Subwoofer Box Breaking
Sounds like your box is made of particle board and proably thin. If you do not want to build a new box you can put a new face on that one. Remove the covering (carpet or whatever) and cut a new face foor it. I would recommend using 3/4" MDF. Glue and screw that to the top of your old box, cut the sub holes, and there you go. Not only is the box repaired but with a dbl baffle a bit stronger.
Also if you go that route make sure you clean off any glue and carpet residue left on the box before attaching the new baffle.
1999 Corvette coupe 600rwhp and way too much stuff to list everything here. Audio Pioneer AVH P7500 DVD w/xm 2 PG Ti 600.2 1 PG TiDEQ Stinger battery,alternator,wire,cap,fuse blocks 1 JL 12w6v2 1 7" monitor in rear MB Quart 8" 4" and tweet in each door Custom fiberglass,plexiglas, and aluminum amp rack carbon fiber sub enclosure |
are you just screwing straight into the wood or are you predrilling the holes?
Any wood will split if you just try to screw straight into it that close to the edge without predrilling
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
I did pre drill the holes so it wouldnt split. The wood isnt splitting, the enclosure is breaking off into little chuncks that is in the inside. Then it doesnt sound good because i have the pieces rattling when the subs hit. I dont know how expensive the box was because I bought it from a guy at school but it is thick so its not a total p.o.s.
What parts are breaking off?
I'm sorry, I've just never seen a box start breaking. From what you're saying it sounds like your box is just disintegrating.
Particle will board will do exactly that...break off into little pieces. Especially if the screws are put very close to the sub opening. It can and does often happen even with a predrill. Did the box get wet?
sr20de4evr, there is the 2 openings for the subs. On the inside of the those openings (not the carpeted side) is where little 1 inch pieces are breaking off. But according to SickVette this is normal, and no the box didnt get wet.
Not normal...it just happens. Particle board is the best at staying together. It is just a bunch of little pieces of wood and sawdust pressed and glued together.
