Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-19-2004, 08:18 PM
ISOKE9 ISOKE9 is offline
Send a message via AIM to ISOKE9 Send a message via Yahoo to ISOKE9
Unhappy 235 miles from a full tank. Please help
I own a 2001 Maxima GLE 45,000. It is 100% stock.
I am only getting 235 miles from a full tank of premium gasoline!
Can someone please help diagnose a potential problem I have.
My wife drives the car with the baby, so she isnt speeding around, or heavy on the foot. CAn you expects please often some advise
oxygen sensors (I have 3)
Mass air flow sensor
Fuel filter?
Should I replace them all? Is that the problem?
Old 05-19-2004, 09:11 PM
anybody with advise? please i am begging?
Old 05-20-2004, 02:52 AM
SkyTorch's Avatar
SkyTorch SkyTorch is offline
Re: 235 miles from a full tank. Please help
I don't know if you're up to date with maintenance, but here is the normal Nissan recommended schedule:
http://www.maxima.org/shoptalk/sub_c...en_sched.shtml
It will give you a place to start. But 11.5 mpg? Is it running normally?
Old 05-20-2004, 07:25 AM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
When was the last tune-up including timing check, wires, cap, rotor, tire pressure check...etc....
Old 05-20-2004, 08:52 AM
It does not appear to show any signs of trouble. IT has not had a tune -up since it has been new.
Is it time for one?
If so what are the components that I have to make sure get changed.
THank You skytorch & helmuth
Old 05-20-2004, 12:17 PM
vinceleto vinceleto is offline
Re: Re: 235 miles from a full tank. Please help
I have a 2000 Max SE the link above say's to change the spark plugs at 60,000 miles. Is that right I thought I read their good for 100,000 miles?
Old 05-20-2004, 06:48 PM
Genachka Genachka is offline
Send a message via AIM to Genachka
Re: Re: Re: 235 miles from a full tank. Please help
I changed my plugs after 83k miles. The original NGK plugs were dead, should of been replaced earlier. I recommend that you do.
Get NGK platinium plugs. I got NGK Irodium, the most expensive ones, and they end up running cold because I run the car stock.
Old 05-21-2004, 08:46 AM
MChapel MChapel is offline
If the car is doing a lot of short trips (less than 5 miles) and most of your dirivng is in stop & go traffic, the mileage you're getting is understandable.
Double check that your wife isn't driving with her left foot resting on the brake pedal, as well (something I've noticed people doing a lot more recently).
Old 05-21-2004, 12:31 PM
Helmuth48's Avatar
One last thing....don't forget the air-filter....
I replace it every 15,000 no matter what!!!
Old 05-22-2004, 09:53 PM
Pick Pick is offline
fulel filter?
Old 05-22-2004, 11:38 PM
Spaz Spaz is offline
No cap and rotor on the maxima. All electronic distrobution, even through the latest generations if I remember correctly.
How's the idle? Choppy? Could be a shoddy Throttle Position Sensor - as I've posted before.
Could also check:
fuel filter
air filter
PCV valve
fuel return line
give it a shot. let us know what's up.
Old 05-25-2004, 06:28 PM
Re: Re: Re: Re: 235 miles from a full tank. Please help
Did you replace them your self or have someone do it. Just curious if you did it yourself how long it may take and how hard it is to get to the
plugs near the firewall. I thought 100k sounded to good to be true, did you notice a difference?
Old 06-04-2004, 04:49 PM
torvan torvan is offline
On my 99 Maxima SE, we noticed the feul economy dropped the closer we got to 100K on the original NKG plugs We replaced the plugs (took maybe 15 minutes tops) and boom-we now get about 450 miles per tank on your average city/highway mix. We also noticed a HUGE increase in performance.
It wasn't difficult at all to do--even I could do it and I am nothing but an engine newbie.
While you are replacing the plugs, switch out the air filter and do a complete oil change as well--your basic tune up.
Old 06-05-2004, 09:09 PM
Torvan:
I don'nt want to sound like a jerk but I have a few questions.
How big is your tank?
Do you get 450 miles mostly highway and all the way empty, I mean with the light on and everything?
I know spark plugs can make a difference but 450 miles city-highway sounds a bit much or my 2000 sucks way to much gas. I recently got 350 miles to 14.5 gallons thats about 24 MPG from honest city-highway driving. I also have a bike rack on my roof which may cause a little drag but can't be that big of a deal. If you got 450 miles on 15 gallons thats
30 miles per gallon if you were bone dry maybe you used 16 gallons thats 28 MPG. What do you get on highway driving 600 miles? just kidding hahaha. Let me know if you have done anything else to get such good milage.
