Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-19-2004, 05:59 PM
djnkat2424 djnkat2424 is offline
Check Engine Light On...Failed Smog
Two weeks ago the check engine light lit up on my 2000 4Runner SR5.
I brought it to the dealership and they tightened the gas cap and told me it would turn itself off within 7 - 10 days. Well...here we are 2 weeks later, and not thinking much about it, I took the 4Runner in for a smog test which, surprise, surprise, it failed.
I can't imagine that a simple twist of the gas cap could correct a check engine light. I thought they were just being lazy!
Anyone have a similar experience? Suggestions?
Old 05-19-2004, 08:38 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Check Engine Light On...Failed Smog
Get the code(s) showing from the computer.
Old 05-23-2004, 07:22 PM
pswadey pswadey is offline
without checking the codes you're in the dark.
Old 05-23-2004, 11:01 PM
Dallas4Runner Dallas4Runner is offline
One of the primary reasons for the check engine light has been the malfunction of the Oxygen Sensor.
I had good luck with my Accord after replacing it; no more light!
Go by the dealer's part dept. and ask them the location of the sensor. See if you can remove and examine it(usually parts guys are very helpful and tell you what symptoms to look for).
The sensor runs about $130.00 but if this is the problem you might be in for a reasonably priced repair.
http://www.autopartsauthority.com/ox...er~~parts.html
Good luck
