Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 05-19-2004, 05:16 PM
1998civicsi 1998civicsi is offline
cool starter...
hey guys,
first off I would like to know what you guys think of those push button starters you can install on your car. and also how how are they do install yourself?
Old 05-19-2004, 06:37 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
I installed one on my car, was fairly simple.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 05-19-2004, 08:52 PM
soo,,,
so how did yu install it? what kind of button did you use?
"It stock now baby, but you gotta start somewhere!"
Old 05-21-2004, 10:07 AM
riccimangan riccimangan is offline
Re: cool starter...
its fairly simple, you need a push button switch and not a click or toggle switch because you want the starting motor to stop turning when you release the button rather than having to switch it back off, then remove the casing around the ignition lock, you need to run the wires from the switch to the wires at the back off the ignition(cant remember the colours so check a haynes manual or something like that). Hide away all the wires and your finished. depending on how you do it, you might still be able to turn the starting motor even when the keys are not in the car, but dont worry about it, the engine wont start,if you dont want to have it like that then you can split the possitive wire on the starting motor and connect the switch to that instead..........,,,,,,,,,,.......
Old 05-21-2004, 10:12 AM
krstofer krstofer is offline
Send a message via AIM to krstofer Send a message via Yahoo to krstofer
Re: Re: cool starter...
I had to do this in a car once. I had a 63 galaxie that I lost the keys to.. So first I had to hot wire it to get home, then I installed an "on switch" and a starter button. Just make sure the button is rated to handle the power from the battery. Don't get some chincy button.
Why do you want do you want to do this? Maybe you should consider a remote starter.
krs
M3FU.COM
Old 05-22-2004, 05:50 PM
1gspot's Avatar
1gspot 1gspot is offline
Send a message via AIM to 1gspot
Re: cool starter...
I dunno its not really for me, i figuer if you already have to put the keys in and turn it to the on position why not just turn it one more position and save all the trouble of putting in a push button ignition, style maybe, i dunno. I believe things that make stuff easier more organized or more functional are cool, pushbutton ignition just seems like more complexity
