Old 05-19-2004, 02:25 PM
dmund dmund is offline
Silverado Problem
Hello, everyone. I have a 2001 Chevy Silverado K1500, my problem is that I have had this truck in the service dept. for the past two years trying to locate a noise inside the cab. The service dept. has worked on and replaced parts on the truck more than 6 appointments. Still the problem has not been located and I am 3 months away from running out of factory warranty. I don't have faith that the truck will ever be fixed and would like some suggestions on what I should do next. I plan to call general motors, any other suggestions would be appreciated. Thank you.
Old 05-19-2004, 08:09 PM
mjgjr72 mjgjr72 is offline
Re: Silverado Problem
if the problem was reported and not fixed it should still be covered even after the warrenty runs out, if they give you a problem you can try for the lemon law, ( what kind of noise)
Old 06-04-2004, 10:20 AM
ditchwitch ditchwitch is offline
ask if they use a chassie ear , thats what we use to find noises and they should to,it will almost pinpoint to your problem.maybe that will help you
ditch
Old 06-05-2004, 04:11 PM
vnotaro vnotaro is offline
Re: Re: Silverado Problem
This is correct. If you have an ongoing problem that you've complained about before the warranty runs out and they haven't fixed, the dealer should still honor the warranty for that particular problem.
Old 06-05-2004, 09:40 PM
desertmike1 desertmike1 is offline
What kind of noise?
Old 06-06-2004, 10:57 AM
Galaxi-99 Galaxi-99 is offline
yea,,,,what kind of noise.
thump thump,
kreeeeeck as you go over a speed bump. (cab mount)
clicking sound as you turn( half shafts)
tick tap knock??? under you ?under the pass side ,behind you under the truck.
If it was me i would check the upper shock mounts and lower since i would be their.
check the bumper mounting bolts,,they do talk when they get loose.
oh,, the bed mounting bolts chattered on my 98 4x4 excabshort box .I had to back them out about 1/2 inch and put thread lock on them and tightened them back up and so far so good.
