Old 05-19-2004, 12:41 PM
Jason Charette Jason Charette is offline
Send a message via Yahoo to Jason Charette
Question 97 s-10 blazer please HELP
I have a 97 s-10 blazer 4.3 lt 4wd. When I go to start it the moter turns and nothing else. it dont start. I lisened for the fuel pump and didnt here it so I tried the relay panel I jumped the relay and the pump turned on so I thought ok bad relay I got anouther relay and still no pump. Does any body have any Ideas at this point Ill try anything even gasoline and a match.lol...
Old 05-19-2004, 07:09 PM
Re: 97 s-10 blazer please HELP
still need help
Old 05-19-2004, 09:01 PM
sraymond sraymond is offline
try the ignition module
Old 05-20-2004, 08:29 AM
Macgyver007's Avatar
Macgyver007 Macgyver007 is offline
Send a message via MSN to Macgyver007
or try an volt meter to find out if the ign module is trying to trp the relay. sounds like the module is not working to me. Either that or its a bad connection between them. the ign module and the relay.
I love these trucks !!
I have had an 84 and 89 Pickup X-cab P/U also assorted 2 Dr Blazers.
I now own a 97 4 Dr.
Still a work in progress but ...
http://www.cardomain.com/memberpage/761008
Macgyver
Ontario, Canada
Old 05-20-2004, 01:39 PM
Question Re: Re: 97 s-10 blazer please HELP
Do you know the location or possibly have a pic of the mod. and location. thankyou .
Old 05-20-2004, 03:17 PM
Jeremy-WI Jeremy-WI is offline
I am fairly sure that on a 97 that the PCM energizes the fuel pump relay for a few seconds when the key is turned on and will keep the relay energized if it receives a signal from the crankshaft position sensor(CKP). Once the engine has about 4 psi of oil pressure the oil pressure switch will also energize the fuel pump providing a backup power source. Check all fuses under the hood. Check for spark when engine is cranking
Old 05-22-2004, 07:48 PM
tspencer73 tspencer73 is offline
Same problem here
I noticed that mine which has similar problam...when you turn the key to the on position the dashlights warning light should normally come on and you will here the fuel pump come on too..if they do it will start if they don't it just turns over. I would like to know whats up here to.
Thank TS
Old 05-23-2004, 06:20 AM
tspencer, sounds like you may have an ignition switch problem or a loose wire, fuse, whatever. See if you have power to gages fuse when the dash lights don't come on
Old 05-24-2004, 08:15 AM
Re: Same problem here
Thank TS
I never looked at the lights Mine dont come on either Im taking the cpu in to get it checked.
Old 05-24-2004, 08:16 AM
thankyou for your imputs
Old 05-24-2004, 09:01 AM
still looking for more imputs or Ideas
Old 05-24-2004, 06:53 PM
So have you checked the gages fuse for power with the ignition on? The gages fuse gets power from the same wire off the ignition switch as the one that supplies power for certain engine components. On the ignition switch harness, with the ignition switch in the on or run position there should be 12v at orange, brown, white, and pink wires, along with the two reds that are always hot
Old 05-24-2004, 08:01 PM
eugene_orourke eugene_orourke is offline
I had a similar problem with my 97 blazer. Sometimes when I turned the key the dash lights didn't come on, but all of the accessories did get power. After asking several different body shops what might be the problem, one told me to check out the ignition switch. I've replaced my ignition switch, and since the replacement, I have had no problem starting the blazer.
The switch is pretty easy to replace and its located in the steering column. You can go to a local auto parts store and they should be able to order one for you.
Old 05-25-2004, 04:00 PM
Thankyou Ill look in to it and keep youall informed
