Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 05-19-2004, 12:16 PM
PiggyWiggy PiggyWiggy is offline
Transmission stopped engaging/hold light flashing
Hi,
The transmission on my '92 626LX has abruptly stopped working without any warning. The car was running fine, smoothly shifting without delays until one day I stopped and then pressed the accelerator to go again and the engine revved but the car stayed put. Haven't got it to move since. Have checked the transmission fluid, it's full...
Since then, the hold light has started flashing when I start the ignition. The engine also revs faster than normal when idle, ocsillating between about 1500 and 2000rpm. I was thinking there could be an electrical problem? Or could it be a problem with the transmission itself (hoping not, have had quotes for rebuilding the transmission and its expensive!)
Thanks!
Old 05-19-2004, 12:21 PM
1995 geo tracker's Avatar
1995 geo tracker 1995 geo tracker is offline
take it to a trans shop and have them check it out , i think you are going to have to rebuild it , mazda has always had problems with their auto trans
Old 05-19-2004, 12:25 PM
Re: Transmission stopped engaging/hold light flashing
Yeah, I know Mazdas are notorious for tranny failure, but I thought that was mainly the '93 and later models which have Ford transmissions. I believe the '92 has the japenese built tranny so i'm hoping i won't need a rebuild....... but thanks for the reply!
Old 06-23-2004, 11:42 AM
fileboxcobra fileboxcobra is offline
Lightbulb Try this
Replace the throttle position sensor. Its near the back of your intake manifold.
Old 05-21-2005, 07:02 AM
tony-telstar tony-telstar is offline
Did it fix it ?
