Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
View Poll Results: Why is my car overheating?
Thermostat 0 0%
Radiator 0 0%
Voters: 0. You may not vote on this poll
Old 05-19-2004, 12:07 PM
sweetnwild318 sweetnwild318 is offline
Send a message via Yahoo to sweetnwild318
Unhappy Mazda 323-overheating
water shooting out from overflow valve...am told water is not circulating and the head may need to be cleaned...is there a thermostat per se? What other problems and solutions could there be? Overheats quickly.
Old 05-19-2004, 12:22 PM
1995 geo tracker's Avatar
1995 geo tracker 1995 geo tracker is offline
i would say blown head gasket
Old 05-21-2004, 11:21 PM
Question Re: Mazda 323-overheating
If it was a blown head gasket, wouldn't the car be undriveable? I am still driving the car short distances, and the last 2 days, have had no problems with the water shooting out of the overflow tube.
Old 05-22-2004, 10:58 AM
you can drive a car with a blown head gasket , might not run to well and it will overheat on you quickly , you can always try replacing the thermostat and flush the cooling system and see if that helps
Old 05-26-2004, 07:09 PM
carkrazy1987 carkrazy1987 is offline
if the head gasket was blown the car would not run. i had my mazda blow a head gasket and it just quit running cause it filled the cylinders with water. im pretty sure theres something u can buy that cleans out the cooling system and makes sure theirs no crud in the system.
