Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 05-19-2004, 11:02 AM
Dacman Dacman is offline
Send a message via ICQ to Dacman Send a message via AIM to Dacman Send a message via Yahoo to Dacman
e36 air con trouble
Has anybody had this trouble, i need some ideas
When i press the button to start the air con going not much happens, the light comes on and i get a sound behind the dash but there seems to be no action from the engine bay.
How many connections to the ac pump are there? i can see one and it does look dirty ( have gave it a wiggle bout nothing)
Fuses look fine, not sure bout the relay, can it be tested? how do i know it is faulty?
The drive belts have good tension.
Any ideas anyone, its finally starting to get hot over here
Simon
Old 05-25-2004, 08:06 PM
jeffreyb4me jeffreyb4me is offline
Re: e36 air con trouble
as long as the control panel lights up and shows temp. displays the problem is probably a low freon level in the system. take to someone for a quick check of that, if it's empty the system, obviously has a major leak, if it's just low a recharge should fix it.
