Old 05-19-2004, 10:30 AM
schisler2005 schisler2005 is offline
Need Help Fast
I went to start my honda accord ex and it started up fine and then when I went to put it in gear it wouden't go in to first gear at all and the cluch pedal did not have preasher at all.
PLEASE HELP,
Tom
Old 05-23-2004, 03:43 PM
Phatestman Phatestman is offline
Re: Need Help Fast
First check your clutch fluid, if it is low top it off with brake fluid or clutch fluid. If you top it off and it looses pressure again you have a leak in your line. Fix the leak and bleed the clutch.
Old 05-24-2004, 03:58 PM
another option is that you have a faulty clutch master or slave cylinder.
Old 05-25-2004, 01:58 PM
SenseiAccord SenseiAccord is offline
Re: Need Help Fast
maybe there is something wrong with the pressure plate... just throwing in ideas.
