A/C doesn't work in my 95 prix
i dont know what the problem is with this, but the air condtioning isnt working at all. it sucks having no air conditioning in the summer here so i want to fix it. does anyone know what i can do to fix it myself? i dont want to take it to a shop so......
the first fix is to go and get an a/c recharge kit. i think they cost between $35-50. it's fairly easy to do. if this doesn't work, or doesn't last long, you prolly have a leak in the system somewhere and then it gets hard to trace and very expensive.
Re: A/C doesn't work in my 95 prix
First of all what isn't working? Is the fan working when you turn the a/c on? Is the clutch on the compressor engaging when you turn the a/c on? There are a lot of things that can cause an a/c system not to work other than needing recharged. Did you check the fuses to see if the fuse is blown, did you check to see if there are any traces of oil around the fittings or the condensor? If you find traces of oil around the fittings or condensor you need to fix the leak before recharging the system otherwise a recharge kit is just a waste of money. Without more information it will be difficult to help diagnose the problem. Don't go spending your money on a recharge kit if you don't need it you may only need a .25 cent fuse instead. Investigate the problem and get back with more information!
i dont know which fuse it is. i checked my owners manual, and it doesnt say anything about a a/c fuse or whatever. what fuse am i exactly looking for?
Look in the power control center under the hood. The ac fuse should be located under there. The fuses are labeled on the inside of the cover.
