Go Back   Automotive Forums Car Chat > Mazda > Bongo Friendee
Old 05-19-2004, 09:57 AM
HORNUTTY HORNUTTY is offline
Question Bongo help required
As a new bongo owner I am having trouble entering my vehicle details into my profile....there is no option for bongo friendee....anyone know how to do it
Old 05-19-2004, 08:07 PM
manXman's Avatar
manXman manXman is offline
Re: Bongo help required
Hi HORNUTTY, I was going to welcome you but as I joined after you perhaps it is not right!
Under Make: select Mazda
Under Model: Instead of choosing the drop-down....click on Other (just below the drop-down) And add Bongo Friendee
Hope this helps
manXman
Old 05-22-2004, 08:19 AM
Thanks for replying Manxman...I already tried that and it just doesn`t work...ah well, spose I`ll just have to live with it!
Hornutty
Old 05-23-2004, 12:09 AM
BrianMartley BrianMartley is offline
Hi,
I had a lot of trouble adding the cars as well.
I think it was something odd, like cookies or activeX being enabled - normally I have all these things disabled by default (paranoid security settings).
Try looking at the cookie settings first, then script/activex components. It's a while ago, but I'm pretty sure I had to enable something in the security settings to get it to accept different car makes.
Brian
Old 06-03-2004, 08:21 AM
Thanks for replying Brian. Um....I don`t know how to do that Can anyone help
Thanks
Old 06-04-2004, 06:42 PM
jebusmoore jebusmoore is offline
Talking help at hand
try mpv in the last section thats what i did
Old 06-10-2004, 01:24 AM
Hi,
I'm pretty sure I followed Manxman's method as above, but at first I kept getting thrown out. Unfortunately I can't remember exactly what option allowed me in, but I worked through the following settings...
If you're on Internet Explorer, check your security settings, I'm pretty sure I had to alter mine. (I'm a paranoid IE user, so I have most things disabled)
Go to "Tools" then select "Internet Options". Click the "Privacy" tab. Normally the Cookie settings are Medium, but it might be bouncing cookies, so set it to low.
Then click on the "Security" tab. Click on the "Custom Level". Scroll down the option buttons. Normally I have all ActiveX disabled, but I think I switched on ActiveX controls. I also switched on Scripting options, plus Java applets. Normally ActiveX is on by default and often Java is, so this may not be your problem, but it's worth a try.
My advice would be that if you change anything, just do it to get through the registration process and then restore everything as it was before, that's what I did. Personally I don't let ActiveX or Java run normally, it's too easy for malevolent code to mess up your system.
You can change the settings whilst you're on-line, so it's pretty quick. Register and then change everything back.
hope that works...
Brian
Old 06-10-2004, 03:15 PM
jackson5ive jackson5ive is offline
I had trouble too. In the end I entered 2 cars - the first was our vw golf, then Mazda, other, for the second car, then once it went through I just deleted the VW! (all without changing any internet settings...)
Old 12-23-2004, 10:03 AM
gadgetking8 gadgetking8 is offline
im new i just clicked on mazda then i think it was :other: at the bottom of model then typed in bongo.
