Go Back   Automotive Forums Car Chat > Ford > Contour
Old 05-19-2004, 08:59 AM
jpjohn jpjohn is offline
O2 sensor larger question
I'm wondering now if my O2 sensor actually needs to be replaced. My 98 Contour has only 55,000 miles and I was alerted to the sensor by the "Check Engine" light. After I used the computer to check the code, the "Check Engine" light went off and hasn't come back on again in a week. Should I replace the O2 sensor now, or could it just have been an electrical mistake? Thanks for any info you have.
Old 05-19-2004, 12:13 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Chances are its an 02 sensor. I would occansionally get a cel every couple months and it wouldnt usually stay on any longer than a couple days. If the code persists I would change it, but for now I think I would let it slide.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 05-20-2004, 06:44 AM
Thanks again!
Old 05-26-2004, 06:11 AM
mk828689 mk828689 is offline
Send a message via Yahoo to mk828689
My old contour had the same problem. I went 130,000 with the problem. I could reset the computer and it might stay off for a couple of hours or 6 months. I talked to ford and a mechanic about the problem and they pretty much agreed that aslong as I could reset the computer and it did not come right back on and the car ran alright don't replace it.I got tid of my contour when it had 238,000 miles on it and a check engine light on. Good Luck
