Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-19-2004, 09:34 AM
SRV BOY SRV BOY is offline
intercooler question on non-turbo
I am deciding not to get a turbo for my car until next year, now keeping that in mind I know it would be pointless in the minds of many to buy an intercooler. I have a 95 prelude h22a, when the weather is hot the car lags pretty bad. I have a K&N intake, I know some would suggest to buy a cold air intake system to have the air intake right at the bumper. But remember i live in canada (rain & snow) i dont want to get a heat shield.
Would an intercooler somewhat help my car run better in the hot weather, and would i get some performance gains out of this? Has anyone ever installed an intercooler on a non-turbo/supercharged motor?
Old 05-19-2004, 02:31 PM
GWInquisitor14's Avatar
GWInquisitor14 GWInquisitor14 is offline
Send a message via AIM to GWInquisitor14
Re: intercooler question on non-turbo
I dont think it would help because u would loose a lot of the intake pressure. When you run a turbo with an intercooler, they recomend that u increase the boost just a little bit to compensate for this loose in pressure. You dont want to drop anywhere below your normal 14.7 psi atmospheric pressure
If the car really knew about all this trickery, hed be pretty mad.
FOR SALE
2 10" Alpine 1041 Type R
JBL BP 1200.1 1200 watt RMS amp
Message me if you are interested, make me an offer
Old 05-19-2004, 03:17 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
On turbo-charged and super-charged cars the intercooler is more for reducing the risk of detonation than increasing power output. Increased power output is just a side benefit, and even then the gains are small. I think an intercooler would be useless on an N/A engine.
Old 05-19-2004, 04:14 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
agreed ! GW and polygon pretty much covered what i would have said..... Why dont you just get an AEM CAI with the water by-pass ?? that will prevent you from injecting rain...and as far as snow..usually the filtration unit sits above youe undercovers anyways..in which case that would not be a problom
Old 05-19-2004, 06:03 PM
ok thanks guys
Old 05-19-2004, 08:09 PM
Drifter To Be Drifter To Be is offline
hey curious...
but wouldn't a intercooler lessen ur power in a NA car??
since u got all that tubing the air has to go through before it gets to the engine... since i kno thats one of the benefits of TMI vs. FMI because TMI has less tubing so less lag... so does that mean it might actually screw up ur a/f mix if u run on NA?
Old 05-25-2004, 08:07 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yes putting an IC on yoru car when its NA will hurt power and should not be done at all
Team Lonely Drivers
Old 05-26-2004, 02:27 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
So, you want to suck air in... then cool it with the same air? Won't work at all. The reason intercoolers work on turbo'd/super'd cars is because the compressor heats the air when it compresses it, so an intercooler is an attempt to reduce its temp back to normal temps. The only intercooler system that would work on a naturally aspirated car is either an air-air with CO2 sprayed onto the fins, or an air-cold water intercooler. Neither of which will give you more than 10hp. If you want more power, supercharge, turbocharge, or nitrous.
