Go Back   Automotive Forums .com Car Chat > Toyota > Tacoma
Old 05-19-2004, 02:35 AM   #1
taconacho
33" tires, what gear ratio?
what's up fellow taco member. I own a '04 prerunner 3.4 and i want to know if i put 33" on 16x8, what is the best gear ratio i should look forward to getting. Im not going hardcore offroading, its mainly going to be a daily driven car.
i'd rather drive a toyota
taconacho is offline   Reply With Quote
Old 05-19-2004, 02:42 AM   #2
Snobrdrblinkchik
Re: 33" tires, what gear ratio?
hmm...depends on which gears you already got...
Snobrdrblinkchik is offline   Reply With Quote
Old 05-20-2004, 05:59 AM   #3
taconacho
Re: Re: 33
i dont know what the stock v6 3.4 2wd is so...
Old 05-23-2004, 12:37 AM   #4
Snobrdrblinkchik
TRD? go to ttora.ne.com They have a write-up so you can look up your gears....
Old 05-24-2004, 01:08 AM   #5
horizontaco99
i believe all V6 TRD Tacomas will have 4.10 In that case, 4.56 will bring you pretty close to stock w/33s. If you ever go to 35s, then 4.88s are a good match. Hope this helps. Later
horizontaco99 is offline   Reply With Quote
Old 05-24-2004, 04:41 PM   #6
taconacho
thanks horizontaco!!!!
