Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-18-2004, 10:18 PM
DAVE K DAVE K is offline
85 pontiac
i have a 1985 parisienne 4bbl.
do'es anyone know if this carb should kick
down from a fast idle
or do i just maybe have some stickey
linkage?
thanks
Old 05-19-2004, 07:47 AM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
Re: 85 pontiac
the choke should open by itself once the eingine warms up. But I had the same problem where (once I got it inot high idle) it wouldn't come out of it by itself. One quick tap on the gas should bring it back to normal idle
Old 05-23-2004, 03:20 PM
Re: 85 pontiac
still idles fast,fast to the point i need to ride the brake in town,then diseals like crazy when shut off.
could it be that little elec.dash pot in front of linkage?has something to do with high&low idle.
could be wrong to.
Old 05-27-2004, 12:20 AM
Re: 85 pontiac
i still have idle problems w/85 parisienne 305 4bbl.on the opposite side of carb.ifound a push lever that takes it to a low idle,is this a manual reset?also sometimes it idles very high to the point its hard to shut offother times idles perfect all day.
Old 05-27-2004, 07:47 AM
Re: 85 pontiac
you mentioned that it dieseled too when you shut it off; this could merely be a carb adjustment problem. on the back of the carb (facing the firewall) there should be 2 very small screws. these are some sort of fuel adjustment (im not exactly sure what they do) but by turning them either clockwise or counterclockwise (a very little bit!) this should adjust the carb so it shouldnt diesel when its shut off.
Old 05-27-2004, 11:53 PM
Re: 85 pontiac
i think it is the fuel air mixture you are talking about [think]but i know what you mean
thanks i shall try it
