Old 05-18-2004, 10:13 PM
244 244 is offline
89 Integra MPFI Swap
HI,
Can you use the 89 Integra intake (the whole thing from top to bottom) from a DOHC to do a MPFI to DPFI swap on a 1.5 SOHC?
Also could you use all the wires and resistor box as well?
How about the Distrubritor?
I have a teg ECU from it already.
I did SEARCH but could not find a definitive answer..
THANKX,
244
Old 05-19-2004, 07:38 AM
91civicDXdude's Avatar
Re: 89 Integra MPFI Swap
you can use the injectors, injector plugs, ECU, and resistor box. this is all.
Old 05-19-2004, 10:30 AM
244 244 is offline
Heys,
Thank you for the help, one more quick question, can you use a Civic Intake Manifold JDM 88-91 Si ZC?
Thankx,
244
Old 05-19-2004, 12:09 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
i believe you can, cause the ZC is a D-series motor
KoRnSaQ
Old 05-19-2004, 01:29 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
You can use the SOHC ZC Intake manifold but NOT the DOHC one. You can also use the intake manifold from a 88-91 Civic D16a6, in which I do have for sale right now.
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 05-19-2004, 01:33 PM
ZCrazyman ZCrazyman is offline
there are many sites out ther that tell you what u need but basicly u can use...
Si distro 88-91
Si ecu 88-91
Si intake 88-91 (sohc ZC will work)
Si resisot box 88-91
any honda resistor box will work
and some misc ecu wires and some other misc wires for the ecu and injectors and a GUIDE off a webiste it is very strait foward and easy i do have some of the parts u need for same in the classifieds
4th gen Civic... is there a better car to own??
My Ebay Items for sale: and more to come... CHECK THEM OUT!!!
http://cgi6.ebay.com/ebaymotors/ws/e...sort=3&rows=50
Old 05-19-2004, 10:18 PM
244 244 is offline
Re: Re: 89 Integra MPFI Swap
Hey T-MO,
I did PM you awhile back you responded to my first PM but not my second...
244
Old 05-20-2004, 12:35 PM
T-Mo's Avatar
my bad I didn't see it. I have replied now
'93 Honda Civic EJ2
Old 05-20-2004, 12:46 PM
travagliante's Avatar
travagliante travagliante is offline
remember
Almost all the time
DOHC bolts onto DOHC
and
SOHC bolts onto SOHC.
and
Engine series dont mix:
ex:
dseries on d series
bseries on bseries
fseries on fseries
kseries on k series
You get the point. May parts can be mixed though.
