Old 05-18-2004, 09:59 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Exclamation '97 Escort Problems...HELP!!!
I posted previously about the TDC positioning on the block of a 2.0 SPI engine, just recently rebuilt the head, resurfaced both the block and the head, reinstalled and reconnected everything in the correct order, almost a picture-perfect installation of everything, and yet once everything was connected, there was power, but the engine wouldn't turn over at all. It was almost as if the engine had locked up or something. You could hear the starter click each time the key was turned over like it was trying to start the engine, but it just seemed as if the engine wouldn't budge. At first we thought that there might not had been enough battery power, so we put it on the charger to see if it would start, and the only thing it did was click over like it was trying to start and if it was held over long enough, it sounded like something was burning. We changed the plug wires with a different set because the conductor inside the number two plug was smashed up pretty bad, and yet still no change. Is there something that I haven't done, or something that needs to be done? I'm so confused, I've put almost over two weeks into this, and I'm very lost. I'm beginning to think that all of my hard work was for nothing. Please, if anyone can help me figure this out, it would be greatly appreciated. Thanks in advance.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 05-19-2004, 01:12 AM
mudman mudman is offline
Banned
Re: '97 Escort Problems...HELP!!!
can you crank the engine over by hand? ie. put a wrench/socket over the crankshaft and rotate the engine? you need to find out if it is seized or not.
Old 05-19-2004, 07:51 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
is your starter wired in right? check your connections to your battery, make sure they're clean and tight.
Old 05-19-2004, 08:52 PM
I couldn't get the engine to crank by hand at first, but I decided to have someone dump some fresh oil into the valve cover while I attempt to turn it, which help a great deal, the engine turned completely, and smoothly, after that, it started right up. Thanks again you guys, I really appreciate all your help.
Old 05-21-2004, 11:19 AM
Banned
Glad that I was able to help. Just wish I could get my car fixed now. Just got back form trip and willl get on it today.
Old 05-21-2004, 03:43 PM
Well, thanks again, hopefully you get your ride going too...
